3 point hydraulics Max26
/ 3 point hydraulics Max26 #1
vietvetharry
Upstate SC
Mahindra Max26XL Shuttle, Montana C4864
I had to remove the FEL to weld the support frame that broke. I looped the two hydraulic lines that were going to the FEL controller thinking that would keep the system closed, but now the 3 point will not lift. Do I need to bleed the lines or do I have to reroute the hydraulics differently? HELP please.
/ 3 point hydraulics Max26 #2
Hi Harry, there should be 4 hydraulic connections to the loader and disconnecting those should be the only thing 'ya have to do.....
Joe H.
Thanks Joe, but I also had to remove the frame to have it welded and that required me to disconnect the joyshick and hydraulic lines. I capped the three connections on the hydraulic block that went to the FEL and the one that went to the rear for the backhoe. The 3 point still will not lift except by hand.
/ 3 point hydraulics Max26 #4
Ok Harry, I got it now!! Have to draw me a picture..lolol. Guess I can't help in this regard. Hope 'ya find the cure!
Joe H.
/ 3 point hydraulics Max26 #5
Can you post photo of what broke?
ALLEN AR16 BUGGY (A63569)
ALLEN AR16 BUGGY...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
Bobcat T66 Compact Track Loader (A64047)
Bobcat T66 Compact...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
John Deere Loader Frames (A63116)
John Deere Loader...
