TYM TX 3500 Cannot switch between forward/Natural/Reverse
/ TYM TX 3500 Cannot switch between forward/Natural/Reverse #1
Bob's-Tractor
TYM TX 3500
Hello All,
I have a TYM TX 3500 with 123 hours. I cannot switch out of "Forward" using the shuttle shift lever. The lever itself will not move at all. It is currently stuck in forward so I can go forward and shift gears 1-4 using the clutch. The clutch does work.
Any thoughts?
/ TYM TX 3500 Cannot switch between forward/Natural/Reverse #2
Um.....are you sure you don't have an actual TYM T353? The TX3500 is usually the loader number, not the tractor model?
You sir are correct. Sorry, it is a T353.
/ TYM TX 3500 Cannot switch between forward/Natural/Reverse #5
I've been troubleshooting some and followed the shuttle shift cable down to the transmission body. See image.
I've detached the cable and the shift levere can move freely. So no issue with the cable.
However, the "shifter" lever on the transmission body will not move.
The "shifter lever", circled in red, will not move
Shown here
/ TYM TX 3500 Cannot switch between forward/Natural/Reverse #10
Iirc, the most likely reason for that problem, if I understand what you are saying correctly, is that the shifter is bound. If you can get it to roll slightly forward or back it should work.
It is currently stuck in "Forward" and I can drive the tractor. I just can't shift out of "Forward" into natural or reverse.
It's in "Forward" and can be driven forward. I cannot however shift out of drive.
/ TYM TX 3500 Cannot switch between forward/Natural/Reverse #13
Sometimes these shifting shafts that come out of the cases are prone to rusting up. Spray with a penetrating fluid and try to move the shaft.
Does it make sense to remove the screw and cover plate and check for rust?
Number 5 & 6
/ TYM TX 3500 Cannot switch between forward/Natural/Reverse #15
Number 5 & 6
I'm sure it is just a keeper that fits in a slot of the shaft. Removing it would greatly aid the spray getting in and would allow to to look for evidence of rust. I would be careful of the shaft moving in or out with the keeper removed though.
I'll give that a try.... Hold my beer.
Is this where I'd check the transmission fluid level?
/ TYM TX 3500 Cannot switch between forward/Natural/Reverse #19
How are you doing on your tractor repair?
2024 HLA MB48 48in. Bucket Skid Steer Attachment (A66734)
2024 HLA MB48...
LeroI 185 Compressor (A64911)
LeroI 185...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
Hustler Standard Style Loader Kit (A66734)
Hustler Standard...
2015 Keystone Fusion (A64912)
2015 Keystone...
