LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,773
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Yep, or go crazy with an aluminum 427.
Yenko 427 Nova! Rarest of rare.Yep, or go crazy with an aluminum 427.
Why not a Yenko 427?And if I had my choice of a 69 Nova I'd get a 396 over a 350.
See the above post.
Yep, saw that after I posted. They took away my "Delete" button.See the above post.![]()
Gotta get special clearance.Yep, saw that after I posted. They took away my "Delete" button.
| Dimensions | |
| Length: | 113 inches 287 cm |
| Width: | 50 inches 127 cm |
| Height: | 73 inches 185 cm |
| 2WD Weight: | 1984 lbs 899 kg |
| 4WD Weight: | 2130 lbs 966 kg |
| Engine Detail | |
| Yanmar 3T84H | |
| diesel | |
| 3-cylinder | |
| liquid-cooled | |
| Displacement: | 87.2 ci 1.4 L |
| Bore/Stroke: | 3.31x3.39 inches 84 x 86 mm |
| Power: | 22.7 hp 16.9 kW |
| Weight | 644 lbs 292 kg |
HP and weight do not directly correlate. Most brands sell 2-4 HP options on the exact same frame. HP goes up, weight stays the same. Some brands are lighter across all HP than others. Kubota, for example, JD for another. Probably due to their superior materials and workmanship. However, Jeff is not wrong that weight improves traction and stability.
For me, it is a both-and, not an either-or situation. Need good HP and decent weight to apply that HP.
HP IMO is quite deceiving. What really matters is torque at a usable RPM. Generally peak hp is hit well beyond peak torque in the RPM range. Very few people are using their tractor in high gear red lined to do much of anything.Jeff is invested in weight as the solution to traction. All solutions are trade offs. Weight works to increase traction, but the downside is that extra weight still requires takes energy to move around whether the extra traction is needed or not. Stability? Maybe, but a little extra wheel width gives more of that.
A lightweight tractor with 4wd would have the same traction as a heavier 2wd...but the downside with 4wd is more complexity. More parts, and with what weight there is needs to be balanced on both ends.
HP as a criteria gives you the ability to do more work faster. Gearing can do exactly the same work but slower.
It's all trade offs.
My preference is a a lightweight 4wd tractor with adjustable wheel width and the ability to add weight. That's my tradeoff. I think that considering weight is fine, but consider the benefits and the cost.
rScotty
spicerparts.com
I'll go along with getting the desired frame size, but I don't like to get the highest horsepower engine in a frame size.
If I need that much power I'll go up a frame size.
My preference is for the mid level to lower end horsepower in the frame size. Often that max horsepower is pushing the turbo and intercoolers to the max, I'd just as soon have enough horsepower and be midway in the range.
1) Jeff is invested in weight as the solution to traction.
snip.
Pretty much exactly what I said. Both HP and weight are needed and 4WD if you are pulling plows.HP and weight do not directly correlate. Most brands sell 2-4 HP options on the exact same frame. HP goes up, weight stays the same. Some brands are lighter across all HP than others. Kubota, for example, JD for another. Probably due to their superior materials and workmanship. However, Jeff is not wrong that weight improves traction and stability.
Pretty much. Torque tells you IF you can pull it; HP tells you how fast you can pull it.Pretty much exactly what I said. Both HP and weight are needed and 4WD if you are pulling plows.
