Finding a reasonably priced 6V tractor battery?
/ Finding a reasonably priced 6V tractor battery? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
My Farmall needs a 6 volt battery and finding one is not as easy at it seems. Rural King doesn't have any, nothing at Sam's or Costco and nothing on-line. I can go to NAPA as a last resort but they are around $150. Since I've seen them around before it must be supply chain issues. Anyone have a better idea for a 6V battery or just go for the NAPA?
/ Finding a reasonably priced 6V tractor battery? #2
If you convert the system to twelve volt you'll probably run into the same thing. Battery prices have gone up a great deal since the US no longer produces lead. The lead in any new battery is most likely recycled from old batteries. Of course on top of that is inflation and lack of availability.
/ Finding a reasonably priced 6V tractor battery? #3
Check with any local golf cart shops...(if a deep cycle battery will do ?)
/ Finding a reasonably priced 6V tractor battery? #4
Find your local Interstate battery dealer. I they don't have one, they can get it.
Thank you. I'll check those places out and no, I don't want to convert to 12 V right now.
/ Finding a reasonably priced 6V tractor battery? #8
Where are you located in Ohio..?? I've been getting them at Batteries Unlimited in Lancaster, but they have several stores. Last one I got was around $100-$120, with full 2 year free replacement warranty. Never had any luck with batteries from TSC, RK not much better. Oldest one I have from Batteries Unlimited is in the 240U, and has been in there for 3 years. Still spins it over like it's new.
Here's a link to Batteris Unlimited, maybe there is one fairly close to you. Batteries | Batteries Unlimited | United States
Good deal and good to know. I get to both Lancaster and Mount Vernon occasionally so your info is good to know. Thank you.
/ Finding a reasonably priced 6V tractor battery? #10
Welcome...
/ Finding a reasonably priced 6V tractor battery? #11
Saw one at TSC yesterday. Think it was about $130-$150. Batteries are expensive, period.
CT
/ Finding a reasonably priced 6V tractor battery? #13
Consider replacing with an 8 volt battery. I see comments on Yesterday's Tractor website about guys doing that to get a bit more juice to the starter on those old tractors, especially for winter. Mine were both converted to 12 volt when I got them, so I have no experience myself.
Tim
/ Finding a reasonably priced 6V tractor battery? #14
I needed 6v batteries and found a local place that services industrial accounts. They had a 6v replacement for good price and they delivered them for free. Probably harder to find a place like that if you live in rural area.
/ Finding a reasonably priced 6V tractor battery? #15
Tim
Tim
Can you pls send a link w the info on 8V from YT? That would be great ! Thx
Also, if you drive to any remote place or local, make sure you take your old battery so you’re not hit w a core charge…
Also,
/ Finding a reasonably priced 6V tractor battery? #16
Sams club shows 6v Golf carts at 109, BUT ... they changed brands & are showing Duracell now. Autozone shows Duralast 6v GC @ 139.
/ Finding a reasonably priced 6V tractor battery? #17
Tractor Supply sells them under the Traveller brand.
Yep. I have a Massey Harris Pacer which is 6 volt and I got a new battery last year from TSC for it. Ignore the specs and for sure ignore the guarantee. Prorated battery guarantees are a joke. Unlike another post above I have had no issues with TSC batteries. Pay attention to whether it fits the hole, where the terminals are so the cables reach and that the cold cranking amps are in a reasonable range. Other than that batteries are double in price what they were 5 years ago. Nearly all you will find in stores are made on a recycled core so do not believe the wonders of some super brand name.
No it makes no sense to switch over to 12v in my opinion. You'd have the generator, voltage regulation, and myriad devices on the tractor right down to light bulbs to worry with. I would not.
Tim
8 volt battery? You gotta be kidding. If 6 volt is rare then 8 volt is in the Smithsonian.
/ Finding a reasonably priced 6V tractor battery? #19
"8 volt battery? You gotta be kidding. If 6 volt is rare then 8 volt is in the Smithsonian."
8 volt batteries are common.
CT
/ Finding a reasonably priced 6V tractor battery? #20
Tim
Also, GOOD #2-1/0 welding lead copper cables. Parts house #4 cables do not work well on 6v.
CT
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
1997 DORSEY AIDT-LSCG  T/A 53X102 DRY VAN TRAILER (A59909)
1997 DORSEY...
2002 International 9200i Truck (A61307)
2002 International...
Engine (A59228)
Engine (A59228)
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2016 Godwin CD225 Silenced Dri-Prime T/A Towable Trash Pump (A61567)
2016 Godwin CD225...
