Robin 22hp EH65 Coil Setting
/ Robin 22hp EH65 Coil Setting #1
3rd Coast
MI
Power Trac PT422
Any tips on setting a new coil in the 22hp Robin? If I recall from the manual the clearance is roughly .012 - .020. Is it as simple as setting a feeler gauge down on the flywheel and setting the coil on that and tightening down?
Also, any tips on reinstalling the motor? What's the easiest way to line up pumps with the lovejoy couplers?
/ Robin 22hp EH65 Coil Setting #2
On the coil gap I suggest having two sets of feeler gauges. It made it a lot easier to keep the gap even. So put one set of gauges near each end of the coil.
/ Robin 22hp EH65 Coil Setting #3
I don't know if it has points and condenser, but if it does, I'd put them in new as well.
Exactly what I did! Really wasn't a bad job at all.
/ Robin 22hp EH65 Coil Setting #6
Yep, what he said. I'm no mechanic but wasn't too bad to install...and what a difference it made for me.
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
SDLanch SDLD25 Rubber Track Dumper (A62183)
SDLanch SDLD25...
Coats 5060AX Rim Clamp (A63118)
Coats 5060AX Rim...
New Holland TS6.110 Tractor with Alamo Boom Mower (A64047)
New Holland...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
