Found a '97, JD 970 4x4
/ Found a '97, JD 970 4x4 #1
nisaacs
Snowflake, Arizona
970 John Deere 4x2, 970 John Deere 4x4, 4320 John Deere, 995 Case/IH
I have had my eye open for a 970/1070 4x4. I have a '94 970 4x2 that is an awesome tractor but won't pull the hat off your head. I picked it up at an auction. Kinda scary because all the items for sale were all non runners. Been parked for years. It is going to be a keeper. After several days of fixing the cobbled up mess, neglect and just unknowing mechanics that were in charge of Maintenance that wasn't being done. It is coming along fine. I have a large order of parts on the way. Pretty excited to get it all fixed up.
I also bid on a JD 5410 and 1600 series ll commercial mower, but let them both go because the 970 was my goal. Picture of the 4x4 and my 4x2. I will post more as I progress.
/ Found a '97, JD 970 4x4 #2
You will be impressed with just how much difference the front wheel assists makes!
David from jax
Told you I had a bushel basket of parts ordered:) Still need a few small items I overlooked and I want a canopy. I might go aftermarket or go oem for a newer model tractor. They are cheaper and more simple. The 970 oem is high dollar and fancy. Note the fan blades, with the right hand engine skirt missing the sun cooked it, the overflow bottle and the plastic fuel canister. They just crumble when you touch them. I need to run to Ace and get some JD green paint.
/ Found a '97, JD 970 4x4 #4
Those are some interesting rear tires. Was this a golf course machine?
Yes, stock turf tire in 44/18x20 tubeless, front are stock 27/8.50x15.
/ Found a '97, JD 970 4x4 #6
View attachment 761698View attachment 761699View attachment 761700
Its a Yanmar kit tractor sent to Deere to assemble in their GA facility.
IF you can not find parts, please reach out to the Yanmar Tractor Owners Group as we have been helping Deere owners for the 50, 55, 70 and 90 Series machines now since the 2020 parts shortages hit. Deere has dropped all kinds of support. Thus, Yanmar has you covered to a degree. :)
The JD970 is based off of the Yanmar F & FX Series machines.
/ Found a '97, JD 970 4x4 #7
Told you I had a bushel basket of parts ordered:) ............. I need to run to Ace and get some JD green paint.
Ace has paint marked as JD green, but you will in a short period of time end up with the blue showing through. Can spot non-John Deere paint from a long ways away when that blue color shows through.
Get the real John Deere paint if you want the green color to last. With all your work fixing this one up, hope you finish it right. ;)
/ Found a '97, JD 970 4x4 #8
Really nice machine! bmaverick- that's good to know as my old 770 is still in the family and will eventually need some things.
/ Found a '97, JD 970 4x4 #9
View attachment 762306View attachment 762307View attachment 762308View attachment 762309
Lookin good!! Had a 1070 that I really liked..
/ Found a '97, JD 970 4x4 #10
That came a long ways in a short time... it's amazing what water and a little touchup paint will do.
I also noticed a couple of older Fords in the background. If you ever happened to post better pictures of those I wouldn't complain.
The dually looks like around '74 or '75?
Good eye, the dually is a '74, the brown 4x4 is a '75. I built the dually in 1990 with a Cummins conversion. I sled pulled the brown truck for 3 years straight in the Rocky Mountain circuits, ('14-'16) in the 6500 lbs street class. The dually was my tow truck in the log woods, 13 years as a gasser 7 as a diesel.
After a lot of research on canopy's, I ordered one from this outfit, they are local to Arizona. It is very similar to the oem on my 4320 and less than half the cost of the oem 970 unit. They are the only aftermarket canopy manufacturer that supplies them to oem's.
- KIT: TAP101 Canopy Kit. Fits John Deere Compact & Utility
/ Found a '97, JD 970 4x4 #13
I was thinking 73 but I am not an expert in those years (although I have a 71 F350 sitting out back).
David from jax
Both JD 970's got chrome stacks yesterday:D
Installed the new canopy yesterday. Seems high quality, fiberglass not plastic. Looks good too.
Doing some work on a JD970 for a customer. First look appeared to be crack in a hydraulic line but after some clean up, it is a banjo bolt washer, I got lucky. The line is expensive and very labor intensive to change. If you look close, you can see the shinny spot on the bottom of the washer, where it was leaking. Note the paint still on the line connector. I will need to inspect the back side. I need to reseal the right bucket cylinder, I did the left side several years ago.
/ Found a '97, JD 970 4x4 #17
My 1070 has the 80 loader. I found out that there is a kit to convert the pinned on bucket to the JD QA bracket system. Everything works, even the bucket indicator. Now I have forks, a tree puller, bucket, and made a hydraulic post hole digger to attach to a loader arm.
Thats good to know. I went from the JD quick attach to the skid steer on my 4320 so I could use my Bobcat loader attachments. Then I ended up with a new bucket and forks just for the tractor. The Bobcat bucket was a little too big and the forks are kinda worn out and hard to shift the forks. I went with the JD kit, so I didn't have to use an adapter, they add length to the system.
This is our monsoon season so the weeds are getting out of control. Using the spike teeth on my cultivator was not working very good so I switched to some duck feet. 2.75" v/s 1.3". Just a quick test, they appear to be going to work a lot better.
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
200 GALLON ALUMINUM FUEL TANK (A62131)
200 GALLON...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63118)
2023 Kubota Z412KW...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
UNUSED WOLVERINE TDM-11-78W 78" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
