Anyone add a tool box to their tractor ?
   / Anyone add a tool box to their tractor ? #1
Vmax540
Clarion PA.
2009 TYM T330
T330 Looking for ideas for a tool box enclosure to mount behind fuel tank above the three point big enough to put chainsaw and a tow chain. Thank you !
   / Anyone add a tool box to their tractor ? #2
A separate chainsaw scabbard/mount would probably be easier than attaching a gigantic tool box, no?
Good thought, although I need to carry bar oil, hatchet,wedges, refreshments....
   / Anyone add a tool box to their tractor ? #4
Carry them in one of your buckets. Seems to me you can't do all that work at the same time. :laughing:
   / Anyone add a tool box to their tractor ? #7
Finished near dark so no pics until tomorrow. I put a 4x4x16 metal tool box on the MX5200 in place of the smaller gray plastic box seen at the left. I looked at so many boxes I went cross-eyed and picked one. My requirements= Bigger than stock but not so big it would restrict my view when hooking up implements when mounted in the OEM spot.
The original PLASTIC box is 2x4x12. I had to remove the SMV sign bracket. It will remount on the ROPS.
   / Anyone add a tool box to their tractor ? #8
I use a similar sized tool box from Tractor Supply on my MX5800. It was an easy swap for the old plastic OEM box:
   / Anyone add a tool box to their tractor ? #9
That one looks nice. But it has the same 4 holes in the back. I used sidewalk bolts (flat head) and rubber washers to seal them up.
What did you do with the SMV sign holder?
And how do you like that MX5800 !
   / Anyone add a tool box to their tractor ? #10
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A54865)
2008 Sterling...
(2) Hydraulic Cylinders (A53316)
(2) Hydraulic...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Peterbilt 384...
2015 Nissan Pathfinder SUV (A55758)
2015 Nissan...
2004 Genie S-45 (A53314)
2004 Genie S-45...
