Anyone add a tool box to their tractor ?
   / Anyone add a tool box to their tractor ? #1
Vmax540
Clarion PA.
2009 TYM T330
T330 Looking for ideas for a tool box enclosure to mount behind fuel tank above the three point big enough to put chainsaw and a tow chain. Thank you !
   / Anyone add a tool box to their tractor ? #2
A separate chainsaw scabbard/mount would probably be easier than attaching a gigantic tool box, no?
Good thought, although I need to carry bar oil, hatchet,wedges, refreshments....
   / Anyone add a tool box to their tractor ? #4
Carry them in one of your buckets. Seems to me you can't do all that work at the same time. :laughing:
   / Anyone add a tool box to their tractor ? #7
Finished near dark so no pics until tomorrow. I put a 4x4x16 metal tool box on the MX5200 in place of the smaller gray plastic box seen at the left. I looked at so many boxes I went cross-eyed and picked one. My requirements= Bigger than stock but not so big it would restrict my view when hooking up implements when mounted in the OEM spot.
The original PLASTIC box is 2x4x12. I had to remove the SMV sign bracket. It will remount on the ROPS.
   / Anyone add a tool box to their tractor ? #8
I use a similar sized tool box from Tractor Supply on my MX5800. It was an easy swap for the old plastic OEM box:
   / Anyone add a tool box to their tractor ? #9
That one looks nice. But it has the same 4 holes in the back. I used sidewalk bolts (flat head) and rubber washers to seal them up.
What did you do with the SMV sign holder?
And how do you like that MX5800 !
   / Anyone add a tool box to their tractor ? #10
2025 MAMMOTH SB-2 2025 SAND BOX TRAILER (A56129)
2025 MAMMOTH SB-2...
2020 Freightliner M2 106 Elgin Street Sweeper Truck (A55852)
2020 Freightliner...
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A56129)
2012 FREIGHTLINER...
2003 Freightliner (A53314)
2003 Freightliner...
