Anyone add a tool box to their tractor ?
   / Anyone add a tool box to their tractor ? #1
Vmax540
Clarion PA.
2009 TYM T330
T330 Looking for ideas for a tool box enclosure to mount behind fuel tank above the three point big enough to put chainsaw and a tow chain. Thank you !
   / Anyone add a tool box to their tractor ? #2
A separate chainsaw scabbard/mount would probably be easier than attaching a gigantic tool box, no?
Good thought, although I need to carry bar oil, hatchet,wedges, refreshments....
   / Anyone add a tool box to their tractor ? #4
Carry them in one of your buckets. Seems to me you can't do all that work at the same time. :laughing:
   / Anyone add a tool box to their tractor ? #7
Finished near dark so no pics until tomorrow. I put a 4x4x16 metal tool box on the MX5200 in place of the smaller gray plastic box seen at the left. I looked at so many boxes I went cross-eyed and picked one. My requirements= Bigger than stock but not so big it would restrict my view when hooking up implements when mounted in the OEM spot.
The original PLASTIC box is 2x4x12. I had to remove the SMV sign bracket. It will remount on the ROPS.
   / Anyone add a tool box to their tractor ? #8
I use a similar sized tool box from Tractor Supply on my MX5800. It was an easy swap for the old plastic OEM box:
   / Anyone add a tool box to their tractor ? #9
That one looks nice. But it has the same 4 holes in the back. I used sidewalk bolts (flat head) and rubber washers to seal them up.
What did you do with the SMV sign holder?
And how do you like that MX5800 !
   / Anyone add a tool box to their tractor ? #10
2020 Ford F-350XL (A53314)
2020 Ford F-350XL...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
20'x20' High End Carport (A53316)
20'x20' High End...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A55788)
2016 Big Tex 14ft...
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A55788)
2008 Featherlite...
