What did I do wrong drilling these holes?
/ What did I do wrong drilling these holes? #11
RPM might be a touch high but perhaps more likely that you hit an inclusion or hard spot in the steel. Mild steel is generally not capable of hardening in any normal situation like this as it does not contain enough carbon to do so. And yes, use oil if you haven't been. Time to resharpen, slow RPM and lean hard on it to see if you can punch past the inclusion. You can try from the other side too and it might work.
This is great information, thank you everybody!!
So, those charts show the best rpm if you are using best bits and want the fastest production times? In other words, they show how fast you can go without things going wrong, ideally?
And there's no penalty for going slow, other than it taking longer?
I did mention pilot hole size, and it was half the diameter of the final hole. I think the web of the final drill would have been maybe 1/4 of the final diameter. I could have piloted at 1/4 the final diameter.
How about chatter? How to avoid that?
/ What did I do wrong drilling these holes? #13
Yes it's perfectly fine to go slower or even a lot slower. It will take more time but you won't have 3/4 of the issues of running too fast. Even cheap drills will work well at slower RPMs as long as they're sharp of course.
As far as chatter, that's also related to too high RPM. A good indicator that things weren't going very well.
Also, on those size drills, I wouldn't even bother with pilot holes.
/ What did I do wrong drilling these holes? #14
Feed rate is just as important as speed.
Since this was a press....and not a hand drill you should have been able to feed at a pretty good rate.
But for starters....mistake #1 was drilling a pilot hole for such a small final size anyway. That puts all the load and cutting action on less than half the bit...
You only need to pilot larger bits that aren't split point. Then you only need a pilot the size of the chisel point/web thickness of the bit.
Second mistake was light oil instead of cutting fluid.
Others mentioned quality bits. Have no idea what you were using...so that could be a factor.
Third thing.....learn to read the chips.....feed it too light for the speed....the chips coming off turn blue......that's too hot. You either need to slow down the speed or increase feed rate......don't let the chips turn colors more than a light straw color on HSS tooling.
100o rpm on a good press with roughly 5/16" holes....going through 7/8" total....should take no more than about 10 seconds per hole. And that would be at a rather light .005 feed rate had you set automatic feed.
I doubt work hardening was an issue with mild steel. Stainless is notorious for work hardening.....as are some high carbon hardenable steels. But not mild steel.
/ What did I do wrong drilling these holes? #15
Probably the tooling. Who made the bits?
Cut your RPM 50% (to 500) and try a few more holes, it can make all the difference on cheap Chinese bits.
/ What did I do wrong drilling these holes? #16
I like that “read the chips” advice. Proper cutting is removing heat. Heat kills cutting edges. I keep my drill press on the lowest speed. TapMagic and pressure for a good chip curl works for my cheap drill bits.
Applying the oil? I use a long tip squeeze bottle.
/ What did I do wrong drilling these holes? #17
My only comment is... You need to learn how to properly sharpen a twist drill (off hand sharpening) and do it regularly plus relieve the heel so the drill requires less downward pressure to cut. Only time I throw away a drill is when it becomes to short to be of practical use any more. I use quality made HSS (as well as cobalt alloy) HSS drills like Cleveland Twist, never Chinese junk. I also drill hardened tool steel with Tungsten Carbide die reclaim drills but that is another subject not relevant to this.
People are always bring me their dull screwed up drills they ruined because they didn't use proper lubricant or speed and toasted them and keep on pushing...lol I can fix them but they get a bit shorter.
Off hand sharpening is an acquired skill. Takes 2 hands and coordination to produce a cutting edge and at the same time, grind in the required relief.
I suggest you purchase a Drill Doctor and use that and don't wait until the drill won't cut anymore (and keep pushing) either.
/ What did I do wrong drilling these holes? #18
This is a good thread.
I keep my drill press set on the lowest speed.
I think the chip comments are important, we need to be aggressive with the down pressure.
/ What did I do wrong drilling these holes? #19
I have only used WestLube which is now AnchorLube for a lubricant to drill holes for about 40 years.
Just a little dab of the green creamy stuff does the job.
I only use a pilot hole in mild steel for 1/2" diameter holes and larger.
135 degree jobber type bits works for me in a handheld drill.
If it's smoking and/or hot, stop and let it cool off.
Others have given valid information here and this is just mine.
KC
Anchorlube G771 Cutting Fluid All-Purpose Metalworking Compound 8oz Smokeless 195893413515 | eBay
/ What did I do wrong drilling these holes? #20
I have 1/2" and 3/8" mild (low carbon) steel plates I'm joining with a pattern of 5/16-18 bolts, and am drilling 11/32" through holes for these bolts. The first three holes went OK, but halfway through the fourth one, the drill started overheating and smoking, and stopped progressing. It was now blunted. So I stepped down to 21/64" and tried again in the same hole, but that one overheated and blunted, too. It looks molten around the leading edges.
Since I had already drilled 11/64" pilot holes and had the assembly clamped together to preserve hole alignment, I could flip it over and drill from the far side, following the same pilot hole. I only had these 11/32" and 21/64" bits, now ruined, so I used 23/64". That worked fine, and my holes are done.
But I want to learn from the experience. So, what's the lesson? What'd I do wrong?
More info: I'm drilling at about 1000 rpm per a chart from a drill bit maker. I'm using a fairly big nice drill press. These bits all happened to look pretty new, especially the /64" ones. The work is in a drill press vise clamped to the table. The holes are all perpendicular to the plates. I'm using a light oil as cutting fluid.
Maybe the first bit was just worn out (even though it looked good) and that made it overheat. But then why did the second one overheat in the same hole? Can an overheating drill bit harden the work beneath it? If this is what happened, I guess drilling to that point from the other side, the cutting edges now at a different angle, got through it just fine. Nothing felt funny about completing that hole.
Thanks!
Cheap drill bits..only get what ya pay for..get high speed steel..carbon steel drill are good in wood.
KENT HYDRAULIC HAMMER ATTACHMENT (A60736)
KENT HYDRAULIC...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2024 Linx 7'X12' UT357714T Single Axle Trailer (A60463)
2024 Linx 7'X12'...
2025 Miva VA13 (A60463)
2025 Miva VA13...
Giyi-D39 QA Trencher (A60463)
Giyi-D39 QA...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
