UTV Winch?
/ UTV Winch? #21
My Taco Wagon ( Ram 2500 Power Wagon ) comes, standard, with a WARN 12K electric winch. I wish I could show, via picture, how much heavier the wiring is in the engine compartment because of this winch. I got the Taco Wagon, new, in 2019 and have yet to need the winch. If I were to do SERIOUS 4 wheeling - a double fluke boat anchor would be stashed away on the pickup. There seldom seems to be a good anchor point when you really need one. A boat anchor was standard equipment when four wheeling in Alaska. The scrawny birch and spruce trees were NEVER good anchor points.
Knowing the build quality of those trucks like I do, when you do use it, be careful as you might cause severe wheel misalignment due to front frame failure... :p
/ UTV Winch? #22
......................... I got the Taco Wagon, new, in 2019 and have yet to need the winch. ..........................
I've had winches since around 1975 and haven't used one to get myself unstuck once. Have rescued a tractor, cars, Jeeps, etc. over the years. Probably used them more often to yank out shrubs, tension trees while falling them, move stuff, lifted a large cast steel valve, dragged logs, rigged to get BIL's chainsaw out of a leaner tree, and lots of other stuff. Have a project in the works now for a spare 3500# cheapie winch that was gathering dust.
Like many things, if I'd never had a winch maybe it wouldn't be missed. However, after having the first one it would be hard to NOT have one now. Back when I sold a winch along with a vehicle, it didn't take long to get another. Felt like a cowboy without a horse for a couple months.
/ UTV Winch? #23
The rule of thumb for a self extraction winch is at least 1.5 times the weight of vehicle. So for most ATV or SUVs a 3000-lb winch works. Tiny truck weighs 2500 fully loaded, so I fitted a 4500-lb winch.
For a recovery winch you need about twice the weight of the vehicle you want to recover. You can go with less if you have the gear to set up a couple of turning pulleys. And recovering a heavy vehicle with a lighter vehicle will probably require anchoring the light vehicle to something, or you’ll just drag it around.
/ UTV Winch? #24
I carry one of those 'Made in USA' chainsaw powerhead winches in the truck when we go camping off road. Fits in the receiver hitch on the back or the one I added on the front. Think I used it maybe once but I do use the chainsaw a lot for cutting campfire wood. Only takes a couple minutes to remove the guide bar and secure the powerhead on the winch chassis and no heavy duty wiring or anything else needed under the hood. Stows in the cross over toolbox if needed. Depending on the chainsaw powerhead power, it will flat pull up to 12K pounds, single line.
/ UTV Winch? #25
^This is me!
The ONLY time I got stuck (broke through the ice) and needed to winch myself out, there wasn't anything to anchor to within 200 yards. It was 10 degrees out, ground was frozen rock solid. Most of the time I use my winch to move fallen trees off the road.
/ UTV Winch? #26
Did the Massey Ferguson 240's backhoe hold the truck in place?
No the backhoe wasn't on then.
There was a chain from the truck to the tractor.
/ UTV Winch? #27
Had 3 Warns (old Belleview 8K, 8274 and now a XD9000i on a multimount. Pleased with all of them with the small exception that the old Belleview was power-in only. However, after watching many vids of Matt, Fabrats, Casey and others I wouldn't hesitate to get a Harbor Freight 12K. Can't beat the price and it looks like they work fine.
Connections are via 2/0 welding cable with crimp lugs and 300A Anderson type plugs.
I also have numerous winches from 3K to 25K, including a Warn 12,000 and a HF 12,000.
Look up the duty cycle of the HF winch, it does work fine, but you really have to take your time with it, if you want it to last.
My Warn 12K, it has made some amazing long pulls, pulling my loaded PU and it puts the HF winch to shame in every way, except price! lol
SR
/ UTV Winch? #28
Who is going to make the first water-cooled electric winch with a lithium battery?
Why are these winches still old technology?
I want one I can carry in my pocket!
:D
Bruce
/ UTV Winch? #29
Discussion of tools on TBN ultimately leads to Harbor Freight as the go to source. On the other hand I don't see professionals in the field using Harbor Freight tools. You would think pros that have to replace tools often because daily use wears them out would wise up and stop paying 3 and 4 times what they would at HF.
/ UTV Winch? #30
Mile marker two speed 10,500# hydraulic winch off the power steering pump. Continuous duty. High speed quickly deploys or retrieves cable. Use mainly to control the fall of trees off fences, property lines and around buildings.
/ UTV Winch? #31
Is that the right picture? where's the winch?
/ UTV Winch? #33
If you zoom in you can see the fairlead in the front bumper. To pull a tree have to anchor the truck to another tree or tractor with grapple or bucket in the ground.
Never been impressed with several of the electric winches I’ve used for other than self recovery.
Hydraulic winches are scary strong.
PTO winches have serious muscle.
/ UTV Winch? #34
Your best bet by far would be a Hydraulic winch or an old style pto winch converted to run off your tractor pto
/ UTV Winch? #35
Thought this would be the best place for this question. Rural King sells their brand of UTV winches that are pretty well priced. 3500# is around $169 and 5500# is around $199. I had a 3500# on my sportsman that drug as big a log as I am ever going to drag and easily pulled that atv out of anything.
I am considering buying one to rig up to the front or back of my GC2400. I know both winches will pull logs easily for me, but has anyone used a winch like this to pull a sub compact tractor out of a situation? Looks like the GC2400 is around 1400# dry weight. I have a fairly step hill that can get slick. I would like to have the winch to help get the tractor up it, if needed.
I know that math adds up but I am sure there are things I am missing or I am not experienced with. The only real winching I have done is with the one on my ATV.
It is not necessarily the size of the winch as long as you have a strong cable. A few snatch blocks properly rigged can multiply the pulling force to amazing levels. I have pulled huge locust stumps with a winch attached very low to the ground on a nearby tree. Be smart. Let mathematics do the hard work for you.
/ UTV Winch? #36
For a once in a blue moon pull that's fine, but for pulling several times a day or row, it's a total pain in the rear to have to mess with all of that, and you need a lot more wire rope!
SR
/ UTV Winch? #37
I reckon it's worth it depending on how stuck you plan to get. I put a small (1500kg - so 3000lb approx) winch on the front of my 4WD Kubota mower as it kept getting stuck in mud when the rains started in winter here. I've used it a bunch of times and it has been worth it's weight in gold. Only cost about £100 I think (about $150). I've used it to haul logs, pull up leaning trees, and other ill advised ventures!
/ UTV Winch? #38
A PTO winch driven from a tractor PTO lacks a reverse capability.
Add a hydraulic motor to that PTO winch and run it from the tractor hydraulics, or start with a hydraulic winch.
Bruce
/ UTV Winch? #39
Go with double the weight you might pulling out..or it will heat up and quit. I bought one for my jd gator from Cabela's..it's a very tuff winch..I have
drug trees with it..after I chained my gator to another tree..
/ UTV Winch? #40
Caution anyone building a pto winch on a tractor to make it have power in and out. Don’t want sudden release of tension on a winch.
Old Dodge power wagons had F/R pto off transmission. Some had pto off transfer case allowing the winch to independently using all the speeds from the transmission.
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2025 SDLanch SDLL60 Mini Stand-On Track Loader Skid Steer (A64553)
2025 SDLanch...
HEAVY DUTY MILITARY TENT (A63276)
HEAVY DUTY...
2020 Peterbilt 337 S/A Dump Truck (A64556)
2020 Peterbilt 337...
Woodsman 332 T/A Towable Brush Chipper (A64194)
Woodsman 332 T/A...
IRANCH Tire Changing Machine (A64194)
IRANCH Tire...
