Starlink
/ Starlink #2,921
My Starlink came today. I barely had time to look at it. But I was impressed with the packaging. I opened it and checked to make sure there was no damage. I still haven’t ordered the roof mount or the starlink pivot mount that I believe I need to go with the S5 roof mount.
/ Starlink #2,922
/ Starlink #2,923
My home unit came yesterday. Package a little ripped but looked ok inside. Will try to install this weekend.
/ Starlink #2,925
I am planning to do a temp install/test on my starling todaynor tomorrow. How hard is it to move it to another location if this turns out to be a bad choice? Meaning, to repeat the setup and discovery process.
/ Starlink #2,926
Not hard at all- I moved mine 3 or 4 times before I finally mounted it to the roof of my shop,
I also was using it ‘temporarily’ on the ground while I waited for the roof mount from Starlink. I would stow the dish and bring it in to the shop when we’d head back home at the end of the weekend. Did this for at least a month.
/ Starlink #2,927
In theory, very simple. But I moved my antenna to the roof yesterday and am having a very hard time getting the system back on track. Maybe a bad cable, or something else-- not sure.
If it helps, resetting to factory specs (plug/unplug 3x) has *always* worked just fine.
Separately, my SL speeds have been seemingly faster lately. Nice to see!
/ Starlink #2,928
It will take you longer to move the antenna than go through the unstow/stow routine. It is pretty quick.
All the best,
Peter
/ Starlink #2,930
Traced my issues to the known SL app issue re: using one phone to config more than one SL system. I was commanding a particular SL router to go into bypass mode. I am connected to that router; the app tells me it reconfigured that router; but I later learn it stubbornly will only issue such a command to the very first SL router that particular iPhone set up. Very confusing.
Last time this "app issue" surfaced, I was in Oregon trying to "stow" my SL RV antenna. But it instead stowed my SL residential antenna in Nevada instead ....
/ Starlink #2,931
I know, you need one of these to label the screen on each phone!
https://www.amazon.com/1749027-Letratag-LT100H-Personal-Hand-Held/dp/B01ISQ7H5S/
Of course reading the screen might be a little difficult...😆
/ Starlink #2,932
Well, I fabricated a highly sophisticated temporary mounting system and after a few technical difficulties, we got it up and running. My speed tests range from 13-70 Mbps. I am letting it collect data for a few hours before I take it down.
/ Starlink #2,933
easy , I had mine sitting in my yard at first with cable under garage door. The app has a stow option for the dish. Do that before unplugging the router, although I’ve moved mine without doing that.
/ Starlink #2,934
That’s awesome. At that angle I don’t think the trees will be a problem.
I’ve been hesitant to set my home unit up using the same phone as my rv unit.
/ Starlink #2,936
Before I left tonight, I took some stat readings.
It did give me reduced speeds during peak hours ranging from 10 to 33. With one spike of 63.
The modem is sitting on the floor in the spare bedroom and I was still able to use the internet on the back porch and in the master bedroom. Depending on performance once we are there , I may get a mesh router. But I have to say that I am ver pleased with this performance so far. The location appears to work so I am hitting the easy button and getting all the mounting paraphernalia ordered quickly.
/ Starlink #2,938
Your obstruction page looks pretty good. Normally there shouldn't be repeated 'no signal received' or other disruptions, so keep an eye out for that. Even though the obstructions page shows hardly any red, that is more 'shadow' than I'd expect, so it could be that there still are some sight issues.
/ Starlink #2,939
/ Starlink #2,940
I brought up my home SL unit tonight, using same phone as RV SL unit, using “set up another“. It went smooth.
First I brought home SL up with it sitting in yard. Once I got that done, I stowed both units, swapped antennas, then swapped router.
Only glitch was the RV unit didn’t work at first after moving it to yard., the cable was not fully seated in the router.
Was easy to swap the mesh unit to the new one, had to first disconnect from RV unit.
Had both working again, then stowed the RV unit. Put RV service on hold.
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
(3) 3 1/2" X 36" HYD CYLINDERS (A64280)
(3) 3 1/2" X 36"...
2019 John Deere R-4038 (A63688)
2019 John Deere...
NEW CHILDS METAL WAGON (A64281)
NEW CHILDS METAL...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
2005 International 4300 Rollback (A62613)
2005 International...
