UTV Winch?
/ UTV Winch? #1
walhondingMF
2012 MF2400
Thought this would be the best place for this question. Rural King sells their brand of UTV winches that are pretty well priced. 3500# is around $169 and 5500# is around $199. I had a 3500# on my sportsman that drug as big a log as I am ever going to drag and easily pulled that atv out of anything.
I am considering buying one to rig up to the front or back of my GC2400. I know both winches will pull logs easily for me, but has anyone used a winch like this to pull a sub compact tractor out of a situation? Looks like the GC2400 is around 1400# dry weight. I have a fairly step hill that can get slick. I would like to have the winch to help get the tractor up it, if needed.
I know that math adds up but I am sure there are things I am missing or I am not experienced with. The only real winching I have done is with the one on my ATV.
/ UTV Winch? #3
Buy nothing less than a WARN or RAMSEY WINCH rated for 8,000-10,000 pounds capacity
with a 2-inch receiver cradle to mount on the front of the tractor on a mounting frame bolted to your
tractors front engine cradle frame or rear on the tow bar or to replace the tow bar for what you need
as you need good wiring and solid gear drive to handle the load you intend to use it on.
Its either the above or a very good CM brand 653 6 ton ratchet chain falls and a long pull strap
as you will be wasting your money otherwise.
The pull loop strap can be looped around a tree and then the chain fall can be hooked to the
loop or loops and the ratchet handle and hook which are on a swivel can be used easily to
pull the GC2400.
/ UTV Winch? #4
I had my GC 1715 buried to frame in mud of seasonal creek and I hooked up my Jeep with 10,000 LB winch,,, Guess what I was able to slide the 4500 pound Jeep till I blocked all four wheels... Yes lightly stick it may be OK with small winch,,,, But if really stuck think 3500 pound winch is not really going to help... Also consider CG series has something like 40 Amp alternator and "small battery".... Winch is going to zap electrical system real fast.... To get my tractor unstuck it put strain on Jeeps electricals (100 amp alternator and large amp-hour AGM cell battery)...
Also consider electric winches are good for recovery, but not for everyday winching like logging.... Electric winches put great toll on vehicles electrical systems...Twice during recoveries I have had winch pull down Jeeps electrical system to around 8 volts, low enough to shut down computer, luckily the AGM battery has enough resilience to come back up after "resting" a little bit to start Jeep again....
/ UTV Winch? #5
I had several 4WD vehicles when we lived in Alaska. My CJ5 had a 10K pound WARN winch. MANY times I had great difficulty pulling the Jeep out of muddy areas. Even with the winch line doubled - Jeep to snatch block - back to Jeep. Effectively - 20K pound pull.
And this was on flat ground. Electric draw would get so great - melt the covering off electric lines going to the battery.
An 8K or 10K electric winch is going to put an excessive strain on your electrical system and battery.
If you go with this size - you should resize all electric lines involved with winch and battery.
Actually - the answer is simple. The electrical system on any ATV/UTV will not support an 8K or 10K winch.
/ UTV Winch? #6
I have a Warn 3500# winch on my Pioneer 500 SxS. Super handy and gets a frequent workout. BUT - there's no way it's going to pull my little Kubota L3800 out, or even worse up a hill. A big load for the 3500# is pulling my lawn mower out of the mud.
All the while, having a winch on my Big Red is comforting.
/ UTV Winch? #7
From the sounds of it here, I wonder if any of these smallish, imported winches have ever been tested for their pull capacity. Easy to print any capacity on the box...
/ UTV Winch? #8
They save their money on them, by building them with a really short duty cycle!
SR
/ UTV Winch? #9
When in Alaska - many times it was either use the winch or quit the journey. I must have learned something from that twenty years of 4 wheeling. Been here 40+ years and have not needed a winch. Not even once. I've learned to recognize and avoid.
Back then I was in my 30's and winching was part of the adventure. Now winching would be just a BIG PITA.
/ UTV Winch? #10
some really good responces in this thread mentioning the lack of electrical capacity to run a big electric winch, a smaller one may suffice if you sheave it down but then it slows the winching time and also the amount of pull ( you get nothing for nothing).
if your mounting on a tractor rather than a UTV a hydraulic winch is the best option ( by far not cheapest) if you have spare set of remotes.
/ UTV Winch? #11
I have another thought. If the OP's tractor has 4WD and still has problems getting up that hill. You would be well advised to wait until things dry out.
Many times a winch will simply get you into problems that are far worse than not getting up that hill.
The same problems could exist with chains on all four wheels.
I speak from a world of experience in this matter. The Alaska outback can be a most unforgiving environment.
/ UTV Winch? #12
2,000# winch paid CDN$49.99 on sale, regularly CDN$99.99. Just need to wait for the sale again, everything goes on sale at PA...
/ UTV Winch? #13
pull the GC2400.
I disagree in part. All the off road rags rate the HF 'Bad Lands' winches very highly and I have 3 and none have ever failed. Buying a name brand like Warn or Ramsey, you just pay for the name and I bet the internals were all made in the same Oriental factory too. I overbuy in pull rating always and I makes sure the electric cables are sufficient as well. I always use stranded copper welding cable to hook them up with crimped on and soldered Tweco solid copper lugs on the ends.
A winch is only as good as the power it receives and poor electric connections are no good.
/ UTV Winch? #14
The other thing to always keep in mind is the inherent strength of what you mount any winch too, especially the frame strength of any ATV or UTV Their frames aren't all that substantial in the first place so mounting a large winch and getting it in a dead pull situation, you could rip the frame apart or at least tweak it and that could be way more costly to repair than your winch cost.
/ UTV Winch?
So you're saying there's a chance...
Just kidding. Glad I asked before I spent the money.
I generally do wait until things are dry but It can stay wet for a while on that hill. It never turns into deep mud but is clay on top of shale so it gets slick.
I talked with a guy yesterday that swapped his R4 tires out for the new versaturf tires. Says he loves them. May give this idea a try.
Thanks everyone for responding.
/ UTV Winch? #17
Rigging a tractor with a winch sounds comical. I've been around farming,ranching and construction over 70 years and never saw anyone rig a tractor with a winch.
I did:
And the front of the truck:
With a receiver mount:
/ UTV Winch? #18
Did the Massey Ferguson 240's backhoe hold the truck in place?
/ UTV Winch? #19
Had 3 Warns (old Belleview 8K, 8274 and now a XD9000i on a multimount. Pleased with all of them with the small exception that the old Belleview was power-in only. However, after watching many vids of Matt, Fabrats, Casey and others I wouldn't hesitate to get a Harbor Freight 12K. Can't beat the price and it looks like they work fine.
Connections are via 2/0 welding cable with crimp lugs and 300A Anderson type plugs.
/ UTV Winch? #20
My Taco Wagon ( Ram 2500 Power Wagon ) comes, standard, with a WARN 12K electric winch. I wish I could show, via picture, how much heavier the wiring is in the engine compartment because of this winch. I got the Taco Wagon, new, in 2019 and have yet to need the winch. If I were to do SERIOUS 4 wheeling - a double fluke boat anchor would be stashed away on the pickup. There seldom seems to be a good anchor point when you really need one. A boat anchor was standard equipment when four wheeling in Alaska. The scrawny birch and spruce trees were NEVER good anchor points.
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2016 Ford Transit 350 Enclosed Service Van (A64556)
2016 Ford Transit...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A64556)
2015 International...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2014 Kia Sorento SUV (A64557)
2014 Kia Sorento...
