steering wheel spinner knob
/ steering wheel spinner knob #2
I have one on the Toolcat and the wife's Deere. Both of those are AWS and power steering. They can really be hand wreckers on a old tractor with mechanical steering.
/ steering wheel spinner knob #3
They work great if you have to maneuver around obstacles quite a bit. Remember that with hydraulic steering, the knob will not stay in the location you originally mount it.
/ steering wheel spinner knob #5
I wouldn't be without mine. Love it!
However if you do not have power steering you better not have one on there. It will break your fingers right now!!
/ steering wheel spinner knob #6
Anybody use one--good or bad ?
Yep. I've had one for 21 years on my machine. Tractor Supply sells a few of them. I'm sure they can be found elsewhere. Really handy (no pun intended), especially when doing loader work, or mowing around tight obstacles.
/ steering wheel spinner knob #7
My tractor is so easy to steer I just use
my palm very fast don't think I would
ever put a knob on my steering wheel
think it would be a hazzard
willy
stupid question--do you put it at 12 oclock or 6 oclock ?
/ steering wheel spinner knob #9
I found a deal on ebay several years ago on wheel spinners. paid 28 bucks for 10 of the same kind that kubota brands as their own so everything has a spinner.
Word of advice is to pop the cap off the top and put a bit of grease or lube on the bearing or it'll rust and seize pretty easily.
If its a hydraulic steering tractor, it'll be at 6 when you put it on and at anyone's guess from then on. Personally I prefer 4 on a mechanically steered unit.
/ steering wheel spinner knob #12
Neither, my tractors are both hydrostatic steering so it can wind up most anywhere.
Mine are both from a local truckstop and are the 'girlie' knobs where the gal drops her top when you use it...
Variety is the 'spice' of life.
/ steering wheel spinner knob #13
Used to use them on old backhoe. New tractor has such great power steering I just use my palm and around we go.
/ steering wheel spinner knob #15
Not sure why you would want it with power steering. We had them on the old tractors and they were very useful but we also occasionally had sprained fingers and wrists.
/ steering wheel spinner knob #18
It was the first addition to my LS.
/ steering wheel spinner knob #19
I love having a steering knob. When your doing hay it makes turning back in on a row much easier than having to spin the steering wheel by and and gives a general reference on when your wheels are straight again. I also like it for loader work as you can keep one hand on the loader controls and the other on the knob. Palming a wheel for hours on end gets old fast. Anything to make life easier when spending hours on the tractor is worth it.
It is annoying how the know ends up in random spots due to full hydro steering.
2023 Kubota L6060HST Compact Utility Tractor (A63688)
2023 Kubota...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61573)
2020 Mack Anthem...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
