Brush Cutter
/ Brush Cutter #1
ColdBlackWind
Member
Trigonia, Tn.
Farmtrac 60
I have a CT322 Deere. It doesn’t have an enclosed cab. Wanting to get a brush cutter to take care of the wooded area of my property. Was thinking about using expanded mesh with 1/8” lexan for a front shield while using the brush cutter. Thoughts??
/ Brush Cutter #2
Old conveyor belt cut to fit and chains have worked for most people for years, I would think that expanded metal would be hard to clean up once clogged up with grass clippings .
/ Brush Cutter #3
Are you putting the shield on the cutter front or behind the tractor seat?
Bruce
/ Brush Cutter #4
Bruce
I made the assumption that he was talking about building a guard for the front of the cutter, but you know what assumptions are good for doing.
/ Brush Cutter #5
A JD CT322 is a skidsteer. So I imagine he will put the guard in from of him.
/ Brush Cutter #6
Google seems to think that Deere is a track loader?
/ Brush Cutter #7
1/8 polycarbonate isn't that thick. I've seen a rotary cutter on a tractor sling a grapefruit sized rock in a split second. What thickness are they using on the OEM shields?
/ Brush Cutter #8
I've used a skid steer cutter many a day with no front glass. Just keep it tilted up if you lift it high. I've cleaned some nasty places with it. I never have it to where I can see the blades.
/ Brush Cutter #9
There are aftermarket skid steer doors available and there’s aftermarket metal door shields if you want something more durable.
/ Brush Cutter
The machine is a track loader and I would be mounting on the front of the cab like a door. I don’t really care for the aftermarket enclosures and one from JD is stupid expensive. Was thinking expanded metal to get some air. A metal door shield sounds interesting. I had not run across that.
/ Brush Cutter #13
I think if the screen is quite heavy you will be fine. BUT.....I think you will get frustrated with the polycarbonate getting dull and hard to see through real fast. I would just use eye protection and the screen and no plastic with the screen. Hope that makes sense.
/ Brush Cutter
Makes perfect sense. I ran lexan on my dirt cars in the day and it mars up at the least touch. High water content. I was going to use a small square at head level to hide behind. I understand exactly.
/ Brush Cutter #15
It's possible that something could hit the expanded metal and be split into fragments that the solid lexan would stop.
/ Brush Cutter #16
I have an aftermarket door on my second skid steer which doesn’t have ac. It’s not that much hotter than without it and helps keep dust down. And the dust off a front mounted mower is ridiculous. It’s not pleasant to run on the open station machine. A mower doesn’t throw stuff that bad as long as you keep it on the ground. When you lift it up which I definitely wouldn’t do on an open station then all bets are off.
/ Brush Cutter #17
I would think if you got heavy enough expanded metal - you would not need any type of plexiglass. When the going get really tough - probably nothing will stop the small crap from covering the operator.
I'll bet some form of dust mask will be appropriate, also.
Massey Ferguson 8200 Flex Grain Platform (A66285)
Massey Ferguson...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
2001 Sea Breeze RV (A62613)
2001 Sea Breeze RV...
NEW Wolverine DB-15-84W Snow Blade (A62679)
NEW Wolverine...
Cub Cadet MOWER (A64557)
Cub Cadet MOWER...
Iranch High-End Tricycle (A64119)
Iranch High-End...
