Brush Cutter
/ Brush Cutter #1
ColdBlackWind
Member
Trigonia, Tn.
Farmtrac 60
I have a CT322 Deere. It doesn’t have an enclosed cab. Wanting to get a brush cutter to take care of the wooded area of my property. Was thinking about using expanded mesh with 1/8” lexan for a front shield while using the brush cutter. Thoughts??
/ Brush Cutter #2
Old conveyor belt cut to fit and chains have worked for most people for years, I would think that expanded metal would be hard to clean up once clogged up with grass clippings .
/ Brush Cutter #3
Are you putting the shield on the cutter front or behind the tractor seat?
Bruce
/ Brush Cutter #4
Bruce
I made the assumption that he was talking about building a guard for the front of the cutter, but you know what assumptions are good for doing.
/ Brush Cutter #5
A JD CT322 is a skidsteer. So I imagine he will put the guard in from of him.
/ Brush Cutter #6
Google seems to think that Deere is a track loader?
/ Brush Cutter #7
1/8 polycarbonate isn't that thick. I've seen a rotary cutter on a tractor sling a grapefruit sized rock in a split second. What thickness are they using on the OEM shields?
/ Brush Cutter #8
I've used a skid steer cutter many a day with no front glass. Just keep it tilted up if you lift it high. I've cleaned some nasty places with it. I never have it to where I can see the blades.
/ Brush Cutter #9
There are aftermarket skid steer doors available and there’s aftermarket metal door shields if you want something more durable.
/ Brush Cutter
The machine is a track loader and I would be mounting on the front of the cab like a door. I don’t really care for the aftermarket enclosures and one from JD is stupid expensive. Was thinking expanded metal to get some air. A metal door shield sounds interesting. I had not run across that.
/ Brush Cutter #13
I think if the screen is quite heavy you will be fine. BUT.....I think you will get frustrated with the polycarbonate getting dull and hard to see through real fast. I would just use eye protection and the screen and no plastic with the screen. Hope that makes sense.
/ Brush Cutter
Makes perfect sense. I ran lexan on my dirt cars in the day and it mars up at the least touch. High water content. I was going to use a small square at head level to hide behind. I understand exactly.
/ Brush Cutter #15
It's possible that something could hit the expanded metal and be split into fragments that the solid lexan would stop.
/ Brush Cutter #16
I have an aftermarket door on my second skid steer which doesn’t have ac. It’s not that much hotter than without it and helps keep dust down. And the dust off a front mounted mower is ridiculous. It’s not pleasant to run on the open station machine. A mower doesn’t throw stuff that bad as long as you keep it on the ground. When you lift it up which I definitely wouldn’t do on an open station then all bets are off.
/ Brush Cutter #17
I would think if you got heavy enough expanded metal - you would not need any type of plexiglass. When the going get really tough - probably nothing will stop the small crap from covering the operator.
I'll bet some form of dust mask will be appropriate, also.
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2022 EZ-GO ELITE...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
