Starlink
/ Starlink #2,901
If you don't have an obstruction free site for the Starlink antenna, you don't. You could always just toss the antenna on the roof, strapped down to some bricks or cinder blocks, see how you do, and go from there. As @plowhog's neighbor's experience shows, it may work just peachy anyway.
All the best,
Peter
FWIW, I had a similar experience. The only suitable dish mounting location I had was the roof peak at the south end of the house.
When I used the pre install iPhone app at that location, it showed obstructions with service interruptions every 7 minutes or so. With little choice, I installed the dish at that spot anyway and have perfect reception with no interruptions at all.
During peak use times, the speed can be as low as 50 / 8 but usually averages 120 / 25. I have seen them as high as 260 / 40 during the early morning hours.
I suspect the app is a bit pessimistic.
/ Starlink #2,902
Can anyone with the RV system confirm whether the cable is removable from both ends (controller and dish)? I know someone who just go this system and they feel like it isn't removable from the dish side because that's how it came in the package. I've not heard of any rectangular dish that doesn't have a fully removable cable though.
/ Starlink #2,903
It’s the same hardware both ends removable.
/ Starlink #2,905
Again, this is from the roof. Going down hill and using a pole might gain me a bit. I am going to try a roof mount first. It should save me a bit of struggle with the pole and hopefully will give me what I need.
I also took a video to show what I am looking at.
FWIW: I'm all in favor of privacy. However, the app does work better if you give it location permissions.
All the best,
Peter
/ Starlink #2,906
All the best,
Peter
I keep pressing to allow “ when using app” but the message doesn’t go away.
/ Starlink #2,907
global outage today we were down over an hour. not sure if they are repositioning satellites due to the last launch.
/ Starlink #2,912
I had that problem as well. IIRC, I had to allow it for all times, or I had to switch devices, I have a vague recollection that it didn't like a tablet for some reason.
@cqaigy2 There was a global outage, so it is/was something major.
We had "network issue" outages intermittently from about 13:30-13:50PDT. Longest was 31s, 2x25, and a handful of shorter ones. The duration was long enough to be noticeable. As out hardware checked out, I assumed that they were having ground station or backbone issues. There were a couple of solar flares earlier in the week, but I don't know why they would have a delayed effect.
All the best,
Peter
/ Starlink #2,913
My Starlink was out for over two hours early this morning from 4:13 till 6:30.
/ Starlink #2,914
I had 3 longer outages in this timeframe, but my networking equipment said there were more outages before this time.
/ Starlink #2,915
They aren't selling that service nor onboarding anyone for it yet. They're just announcing a future offering. You are mischaracterizing things. I'm not defending Starlink's current situation, just pointing out that things are not as you indicate.
No mischaracterizing at all. With my area being rescheduled for 2023 as well as others. The phone deal will most likely happen before all prepaid customers are brought online.
/ Starlink #2,916
Here is my neighbors obstruction report.
He is in a hole in the forest. His antenna is on the roof ridge about 20 feet up. Positioned at the most optimum point pointing out of the hole.
His highest speed has been 120mbps, lowest in single digits, typical is 30-40mbps:
/ Starlink #2,917
I can't make it out in the pic., but does it say there may be an interuption every 17 sec.?
/ Starlink #2,918
It's a blurry image but it's either every 17 secs or 12 secs. Regardless, he does wifi calling without problem ...... and has had good service overall.
/ Starlink #2,919
I will start with a roof mount. Then a pole further from the house if needed. Not eager to drop trees on the ridge line. My alternative is dsl that I paid $1200 to get installed with promise of 20 meg. True max was 9.8 and it failed constantly. When it went out on a Friday, it would be out till Monday or Tuesday.
I could put the cellphone booster up and hotspot. I could try the T mobile 4 g modem that gave me 8-15 meg when I test d it a couple weeks ago. I am thinking that Starlink will be a big improvement over those other options
/ Starlink #2,920
When I purchased SL last year, they gave me an option to return the system if I didn't like it for any reason. Not sure if this option is still available though.
The app said the roof location I wanted to use was marginal but I installed it there anyway. The system works perfectly with no interruptions at all. DEFINITELY better than the DSL service I had.
2004 GMC Sierra 2500HD (A66408)
2004 GMC Sierra...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
BUSHHOG 286 - 6' ROTARY MOWER (A64277)
BUSHHOG 286 - 6'...
SKIDED FUEL TANK (A65643)
SKIDED FUEL TANK...
Suzuki RMZ 450 Dirt Bike (A62613)
Suzuki RMZ 450...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
