Bonehead Move, Need Advice, Loader Quick Attach won't hold
/ Bonehead Move, Need Advice, Loader Quick Attach won't hold #1
rcspott
Montana
2004 Kubota L48 TLB
Was back dragging a brush pile with my pallet forks straight down and hit something. Blew the metal hydraulic hose and the pallet fork popped off on one side. Got that all fixed but now the forks or bucket won't stay on with down pressure. Have tried adjusting the nut on the loader quick attach handles but they are still are very loose. They don't have that camber lock feel anymore. Nothing looks bent, was wondering if I may have compressed/trashed the springs as the lock pins that go into the bucket/forks just want to keep popping up.
Kubota L48
Any Suggestions?
Thanks
Rich
/ Bonehead Move, Need Advice, Loader Quick Attach won't hold #2
Can you post photos of the FEL? Have you set it down on a flat spot to make sure it's not bent?
/ Bonehead Move, Need Advice, Loader Quick Attach won't hold #3
I have a SSQA but pictures as teg has said will do wonders in trying to help.
DevilDog
/ Bonehead Move, Need Advice, Loader Quick Attach won't hold #4
Kubota L48
Any Suggestions?
Thanks
Rich
Without photos, this is all I have to offer:
/ Bonehead Move, Need Advice, Loader Quick Attach won't hold #5
You may have bent or twisted the timing rod between the two sides. Eyeball across both sides of the quick attach plate and see if they are square with each other, or if one is tweaked/twisted. That suggests the timing rod that goes between the two sides needs to be heated and put back straight/true.
/ Bonehead Move, Need Advice, Loader Quick Attach won't hold #6
Kubota L48
Any Suggestions?
Thanks
Rich
Since it popped of on one side, the cross tube is probably twisted.
With no attachment on the QA, do a full dump, see if the cylinder rods are bent.
Check the stops on each side. Put the side that is touching against a tree and slowly extend the other side, until it springs back straight inline with the other side, test by doing a full dump, both sides will be touching the stops.
/ Bonehead Move, Need Advice, Loader Quick Attach won't hold #7
Thanks Xfaxman for the pictures. This is what has happened on my L3901 w/525 loader. I will try what you have said here. I can't see anything bent just that the plates don't line up as in your photo's. Also the same gap at the stops as you show ....
Again, thanks !!
/ Bonehead Move, Need Advice, Loader Quick Attach won't hold #8
Wondering if you swapped the hoses on one of the curl cylinders so one pulls as the other one pushes if you could carefully straighten the tube using hydraulic pressure.
Good luck, Fred
/ Bonehead Move, Need Advice, Loader Quick Attach won't hold #9
Would it be easier to use shims between the bump stops where the white arrow is pointing, then apply pressure in the dump direction? There will likely be "spring-back" so increasing shim thickness till it remains even when the pressure is released?
/ Bonehead Move, Need Advice, Loader Quick Attach won't hold #10
hi folks..gravelman here..i put in a shim on one side...fully rolled out bucket arms...it worked... thanks for that advice...
/ Bonehead Move, Need Advice, Loader Quick Attach won't hold #11
Chim, don't know if you get notified of posts to this old thread but your advice helped me fix this issue with my quick attach. Your suggestion of using a shim was so simple and brilliant. I was having trouble visualizing how putting one side against a tree and extending the bucket was going to correct the problem. Thought I was in for a big $$ repair bill and some serious down time!! See, boneheads keep getting created. So thanks again from a local down the road a piece from you here in Wellsville, PA
Len
/ Bonehead Move, Need Advice, Loader Quick Attach won't hold #12
Len
Hi neighbor! I did get a notice of you quoting my post just today. When I went to look at the old thread I was surprised it was so long ago. Glad it worked for you. My one BIL may have lived near you on Creek Road till he passed a few years ago. Not very old and a great guy. We still miss him.
2017 Ford Expedition SUV (A64557)
2017 Ford...
New/Unused 20ft X 20ft Steel Carport (A65583)
New/Unused 20ft X...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
2024 Texoma 16ft. T/A Equipment Trailer (A64194)
2024 Texoma 16ft...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
