What is in my yard
/ What is in my yard #1
whynot162
Amboy WA
Rhino 324
What's in my yard and how do I get rid of it. There is no mound like a mole have not seen anything and the sonic vibration things have done nothing.
Thanks
I have also baited for mice
/ What is in my yard #4
Chipmunk or ground squirrel.
These are all over and some are connected by tunnels. Some I am not sure of. We have had a few wasps but nothing like in the past I do live in the northwest and in the trees. So I could see a squirrel but I have not seen any of those but pretty sure they are here. Maybe they plant dandelions?
/ What is in my yard #7
I thought it was only one hole. Several connected sounds like voles.
So I have tried putting out grains and peanut butter that is supposed to draw voles and mice and squirrels. Have not have anything taken. I will try again. They seem to dig all over the yard and garden but as far as I can tell they are not eating anything in the garden? Or maybe I can't tell because of what the deer eat...
/ What is in my yard #12
Around here - that's a mouse hole. Pocket gophers leave a mound of dirt. Chipmunks do not dig holes in the ground. I don't have voles nor moles or ground hogs.
When coyotes or badgers dig - they leave a MASSIVE hole.
So if it is a mouse or a vole mouse bait and traps should work. There is no mound around the hole at all.
Any ideas on what to try? I have tried just one bite, and snap traps with peanut butter.
Thanks
/ What is in my yard #15
Or, a cutting torch not lighted. Run some oxyacetylene down the hole and touch it off great fun for all.
There are videos on YouTube of folks blowing up the yard.
On the serious side
/ What is in my yard #16
I couldn't find any measurements my apologies if I missed them. How deep is the hole and what's the distance across? Approximately how many holes have you found and how far apart. Are there any holes that aren't connected.
I'm curious because in years past, I've found numerous holes near black walnut trees. I didn't measure. My guess is that they were an inch and a half across and about the same depth. I thought they might have had to do with deer mashing walnuts into soft ground as they gnawed on them but that seemed farfetched. I didn't notice any tunnels.
The holes are about the size of a golf ball. They are plugged up down an inch or so. No dirt on the surface like a mole.
I can not see a tunnel move like I see in the clips on line. But they collapse under you when you walk over them.
/ What is in my yard #20
Thanks for the size comparison. The ones I've seen might have been the size of a golf ball, too. It's been a while and my memory is not the best. I think they were there in late fall or early winter. I was probably looking for black wallnuts so I could show my grandson how to drive them trough a hole in a board to remove the hull.
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
Club Car Emergency Cart (A64557)
Club Car Emergency...
Allmand 20KW Light Tower (A64194)
Allmand 20KW Light...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
