Hours
/ Hours #1
Kitz
anywhere usa
IH 244
2 identical tractors 1 has 2600 hours 1 has 1700 hours what are the hours worth?
/ Hours #3
Well if you rent that tractor how much would you rent it for ? depending on the size it would vary but lets say 25$/h, they have 900h difference so 900x25 = $22500
Dose the tractor with 2600h is worth $22500 less then the other one? no but you have the potential to buy and rent the one with 1700h for 900h and put $22500 in your pocket ... grand scheme of things they both have low hours but 900h is 900h that 75 days straight at 12h of day, I would always choose the tractor with the lowest hours when there is this much of a difference long as the asking prices are within the same ball park.
/ Hours #4
No single feature can be used to value a tractor. As Jeff mentions, the sum of the parts are what matters. I would put more weight on overall condition rather than hours. If the owner takes care of the tractor it will show by date and/or hours marked on filters, small amounts of grease from joints and the cleanliness of the operator station and engine.
/ Hours #5
There is one thing tho you can clean your tractor, repaint it and change your oil and filters before you sell it, lie about what you used for and where it was stored it but the hour meter never lie... but yes the over all condition matter and there hours is not all it matters, maybe the 1700h was beat up with no maintenance and the 2600h ran idle to run a PTO wood splitter most of its life and the owner did regular maintenance who knows ... judgment is required, but I would not put the 900h differences in consideration.
/ Hours #7
I guess it would depend on the hour meter. My 1986 Ford 3910 meter has 28.4 hours on it. :cool: I just put four of those hours on it this morning cutting the side field. It didn't even have a dash much less a meter the first 12 years I've owned it. I put a new gauge cluster in it as part of the restoration.
But, be assured, there's other ways to tell the age of a tractor besides the hours. You just have to look. ;)
/ Hours #8
Not that I buy many used tractors but I did 2 years ago and first thing I do is look at the tires and compare that to the hour meter. That will always tell you if something isn't Kosher. That and old grease. I want to see old grease where the fittings are. Then I'll pull the dipstick and have a look see at the engine oil but more importantly I look at the transmission oil. People will change the engine oil but not the transmission oil because it's more difficult. I see a lot of for sale units with fresh paint via rattle can. I run away from those.
/ Hours #9
All a matter of which one more beat to ****aki. You could have a 3k hr machine that's well taken care of, or a 100 hr machine that was regularly ridden hard/put away wet (but cleaned up prior to sale).
/ Hours #10
Bent and wonky fel bucket is another good indicator if the tractor was flogged. Bent up buckets or a smile in the cutting lip means it was used hard and probably abused.
One thing people don't know about Kubota's (at least) and that is when you buy a new one, you can opt for either a light gage material bucket (which is what 95% of the come with) or a heavy duty excavation bucket. The light duty material buckets will get wonky pretty easy I have them both.
/ Hours #11
One man using a tractor for 10 hrs could put the equivalent of 1,000 hrs damage on it compared to a skilled operator. Less than 5k I wouldn’t be concerned about hrs as much as use and maintenance.
I’ve had dealers come out with laptop and analyze the transmission pressures and check the pumps before buying on my CVTs and that gave me peace of mind. Other powershift I bought new, so had warranty. Magnum has rebuilt powershift and I know the shop that did it.
I will tell seller I’ll be there a 2 and show up at 1 just to see if anything fishy is going on before I get there. Definitely want to do a cold start and check smoke color on engine. Throw my pressure gauge in the remotes, too. Good for testing pump. Loader should easily lift tractor. Also let seller know you want a PTO powered implement available to test PTO.
ALWAYS check for seeps and leaks.
Look at the cab steps, seat, steering wheel and floor mats to see if hours match wear on them
/ Hours #12
I knew of a dozer that was 25 years old, but low hours. Always kept inside. He wanted new price, but was sold for a lot less. The major problems where all the seals started to leak from drying out. If it had been used more, it might have been in better shape.
I also have a dozer and make sure it is started and run every 2 to 3 weeks. And by run, i mean started, warmed up, and run for at least 1/2 to 1 hour. Also check all fluid levels and grease when needed. Still low hours but used.
/ Hours #13
Yep that's the other side of it right? Machine sitting idle for too long, you get water condensation damage here, chewed up wires there, dry rot everywhere.
/ Hours #14
check the clutch condition if it has one, item oft overlooked but paid dearly to replace. you didn't mention the tractor model or make. does either have a maintenance log? hire an impartial tractor mechanic to check out both. they probably will not last long on the current market but choose wisely. regards
/ Hours #15
I figure that hours are a lot like experience - the more it has, the longer it is likely to last. I'm not going to abuse it, just use it. If it has already lasted thousands of hours that makes me all the more confident it will last that long again.
And that's long enough.
I actually prefer the older ones with with lots of hours, decent maintenance, and not abused. They have personality.
Of course everyone has a limit, and mine is that I won't buy anything with flaky rust, dents, or missing parts. And if it doesn't come with the old manuals then I'm losing interest fast.... Got other things to do....
But faded paint or a floor and controls worn right through the paint down to bare worn metal is OK. I expect to put on tires and a battery - but nothing more.
A well-kept secret is that a used machine with hours that is simply old and worn is easy for anyone to deal with.
Up until about 20 years ago machines were designed for the easy replacement of wear items like bushings and seals. Tractors are heavy, rigid, well-built low rpm machines; they rarely need more than replacing the standard wear items.
And just by being willing to pay what it's worth enables a buyer to pick and choose from the best ones.
rScotty
/ Hours #17
just as a caveat regarding hrs on a meter. some mechanical cable driven tacs are geared to record 1 hr at actual 540 pto rating rpm, so the number of actual "live" hrs (idling, etc lower than the 540 rating) may be more than recorded hrs show.
that may sound academic, but for example actual hrs on a rental may be far greater than the recorded meter hrs if that makes sense if operated below pto 540 rating. electric hr meters record once key is turned on, guess that's the majority these days. think that how it works, please correct me if not.
/ Hours #18
That's right; that's not true of every machine but true of most. It used to be that idling didn't add many hours - but they do add up. The advantage on the hour gauge was offset because it used to be common to let machines idle for hours between jobs. It's just one more reason why old machines are often in better shape than their hours would indicate. High hour machines may not have all that many full throttle hard-working hours on them.
/ Hours #19
hasn't happened so far but....if the ign is mistakenly left on on with an elec hr meter, will it record stationery hrs until battery is depleted? a day or 2 could really add up. done many clueless mistakes & continue to do so, but not that so far.
to the OP: follow up on your purchase if you decide
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2018 Chevrolet...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
(2) UNUSED 15X19.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 15X19.5...
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
