Help! Branson Tractor only IDLES - no Power
   / Help! Branson Tractor only IDLES - no Power
Im sorry to hear about your Father-in-law's passing.
The electric fuel pump?
When you turn on the key does it make a purring sound from the firewall?
Also check the fuses I believe the fuel pump has one on the fuse box.
keep us posted...
thank you! He certainly was a good man.. He always did things for others and never would accept payment.. he actually was using the backhoe attachment for a lady in need...
Yes the fuel pump is eletric as when key is on you can hear the "ticking" sound.
Fuses have been checked and all good.
   / Help! Branson Tractor only IDLES - no Power #12
Have you checked the fuel filter for water/
Maybe loosen up the banjo fitting at the pump while the key is on to see if fluid comes out?
Is the pto switch off?
Is the clutch pushed in all the way?
If its a shuttle is in in the neutral spot?
OK. DPF definitely isn't the issue then. As long as you're getting plenty of fuel to the injection pump and plenty of air to the engine. Outside of extremely low compression, about the only thing it leaves is extremely tight valve lash or injection pump is wore out. I'm assuming you've already made sure the accelerator cable is operating the pump correctly.
checked the accelarator cable/s. It appears the cable to the throttle is tight when i rock it back in forth from turtle to rabbit.
the 2nd cable is linked to the hydrostatic pedal and also appears to be tight when pedal is pressed
yes checked fuel filter and all lines in line to ensure diesel fuel is running out
PTO switch is off and since its shuttle it is indeed in neutral.... idk
   / Help! Branson Tractor only IDLES - no Power #15
About down to the three things I mentioned earlier then. Maybe have the same tech that OK'd the DPF filter look at the flow goin' into the pump and see if he thinks it enough? Should be a decent stream.
You could remove the DPF and run it with just the up pipe that leads to the DPF. Not for long and with the hood open so you don't damage the paint. Just to check if the DPF is the problem.
But if the DPF light on the dash is not stuck on solid or blinking fast, then the data recorder thinks the pressure differential across the DPF is within normal parameters and your problem is elsewhere.
Does it sound like it's trying to increase rpms and struggling to do so? Or is it totally ignoring the throttle lever and just sitting there idling? In the latter case I'd watch the actuator arm on the FI pump while opening the throttle to see if it's moving.
i did remove the dpf and ran it and still idled only. The DPF light will come on when keyswitch is turned on and blink fast for 10 secs and then disappears..
it has never wanted to increase rpms. its totally ignoring the throttle lever and does sit and idles only..
   / Help! Branson Tractor only IDLES - no Power #17
Verify that the lever on the pump moves when the throttle (or pedal) is moved. Or move the lever by hand while it's running.
According to my shop manual blinking every .5 seconds means sensor malfunction. Every 2 seconds, the DPF is getting clogged and needs cleaning. Solid means the DPF is clogged or overheating. At least that's how I interpret the manual. Mine is solid when I start the tractor and then goes out a few seconds after the engine starts. It's done that since new so I think that's normal.
I'd think that if your lift pump was weak it'd rev up at least a bit. It sounds like the throttle cable or the injection pump itself.
   / Help! Branson Tractor only IDLES - no Power #18
I'm betting it's throttle linkage related.
thanks all... i will relay info to my shop tech and have check whats been mentioned and report back.... He is a great diesel mechanic but with no service manual etc.. its a little tougher to diagnosis.
we did move the lever by hand and nada... yes its .5 secs so i was going to order both sensors (temp sensor and pressure sensor)
Greenworks Commercial 82V CZ60R Zero-Turn Mower-DEMO UNIT (A56436)
Greenworks...
167 (A52708)
167 (A52708)
Deere 310SK (A57148)
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56436)
2023 Kubota Z412KW...
Bell 1600 Gallon Nurse Trailer (A56436)
Bell 1600 Gallon...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59575)
2007 FREIGHTLINER...
