K0307 Rotary cutter
/ K0307 Rotary cutter #1
pwmattin
K0307 Rotary Cutter
The clutch housing on the John Deere K0307 Rotary mower broke in several parts. Friend hit something, but knew not what, if you know what I mean. Anyway, I'm looking for a slip clutch housing, or a slip clutch that fits the rotary mower. I have been searching all over the internet, but not luck finding parts for this mower. The mower was manufactured in Canada. The model number says K0307. This mower is not a three point hitch. Any information on finding parts for the clutch or a work around would be greatly appreciated. I found the housing new, but the cost was $500-$600 which is way more than I want to pay. Looking for used if possible. Surly, there are mower decks like this sitting around in fields not being used anymore, just rusting away.
/ K0307 Rotary cutter #2
Hello Hay Dude, checked out the web site, but unable to locate the parts I'm looking for. I may try giving them a call directly and see if they carry any part for this rotary cutter. Again, thanks for the input.
/ K0307 Rotary cutter #5
How does the clutch attach to the gearbox? Splined or smooth bore with a cross bolt?
How does it attach to the PTO shaft?
Perhaps an aftermarket slip clutch could be made to work for less $$$
Thanks for the reply. Looking into pinning the slip clutch and find a third party clutch that will work off the PTO. Added more pictures of the broken slip clutch. There is a another section that bolts to the slip clutch that goes to the PTO.
