Good morning!!!!
   / Good morning!!!! #154,601
Finally got some much needed rain over night into late morning, sure could use 2-3 days of good soaking rain.
We sure could!!
   / Good morning!!!! #154,602
more pics
   / Good morning!!!! #154,603
Paul, that’s become my preferred way to cook corn on the cob.
   / Good morning!!!! #154,604
We sure could!!
We could too. Haven’t had a decent rain since power washing the roof. Catchment still not hooked up as I’d like the gutters to get a good flushing of the bleach soap application even though it was pw with plain water. Fortunately, with 16k gal tanks I’m not concerned.
   / Good morning!!!! #154,606
btw, I saw an Indian/Thai food truck there but nothing marked Vegan.
Overwhelming smell of cotton candy at times. I think you can inhale calories that way...
This is not Mrs Popgadget's stand, but wow there were four alpaca stands there.
   / Good morning!!!! #154,608
Dodge inevitably is phasing out their Hellcats for new even faster EVs. But what about good noises for us motorheads?
Well they have that covered too it seems. The Fratzonic exhaust. Get a new name Dodge...
let's see, a pump pressing air. Don't they call that a horn?
Dubbed the Fratzonic Chambered Exhaust, this system replaces the traditional exhaust note with a facsimile. Without revealing details—again—Dodge says it’s not just a speaker churning out simulated combustion noise. It’s likely some sort of pump that pushes air through a device to generate sound. In a world of nearly silent EVs, Dodge promises this one will be loud: 126 dB—that’s the same peak noise rating as your current Charger SRT Hellcat.
It won't be long until they record the sound of old cool engines and allow us a menu selection.
I've joked about this before. It's coming...
If you could row through the gears, what sound would you like to listen to?
let's see, we have the GM and Ford small block guys, the hemi guys and of course a flat plane crank guy or two. I personally do not like the F1 sound.
but who doesn't want to drive a Ferrari so sure put an older one in with mechanical Webers wailing flat out.
and then your child comes along and snorts how lame you are and you really need the Arch Avenger space warrior blast off sound.
while you would prefer a quiet Engage...with a defeat on the Fratzonic.
   / Good morning!!!! #154,609
Back in place
Paint a bit softer than I’d have liked, but can dry in place
I had put this off too long, but tank solid, just surface rust and blistered paint.
This is a Sears tank, purchased 2006. Keeps pressure well so guessing bladder still in good shape.
   / Good morning!!!! #154,610
never tried, could use a lesson
soak the corn in water first?
thanks
Nope, plenty of Google instructions. I simply clean off the outter husk down to nice clean & tight. Place in microwave for appropriate time according to your taste 5-7 minutes usually for us.
Remove and cut off the stalk end. Need to get above the corner. Then just grab from top and shake out. Usually all silk comes with it. If you didn’t cut quite high enough it can be a challenge, but solvable.
Kobalt 10 Inch Miter Saw (A57454)
Kobalt 10 Inch...
2025 BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
Vicon Seed Spreader Parts (A57149)
Vicon Seed...
Cummins 6 Cylinder Power Unit (A57149)
Cummins 6 Cylinder...
Club Car Electric Golf Cart (A57149)
Club Car Electric...
