how many GPM is needed
/ how many GPM is needed #41
I'm shopping 40-50 hp hobby farm tractor like Kubota, TYM, Mahindra, Kioti new and used. Trying to compare apples to apples I see hydraulic gpm varies a lot. What is a good number for this size? Some tractor have 2 pumps - 1 dedicated to steering, so what's a good number for that one too? Thanks for any help.
When I can I follow this rule of thumb. “It is better to have it and not need it than need it and not have it”
That said you can go way over board too.
You are vague on what you want to attach to the tractor. I would suggest all will supply enough volume to do what you want. Best to check against what attachments you have/may use need though.
I would suggest that you get two rear valves/quick connections. Again better to have it and not need it than need it and not have it
/ how many GPM is needed #42
IF you need flow requirements that exceed the 8-10gpm of the typical 40-50hp machine......simply get a PTO pump. Tractors, for their size and HP.....have relatively small pumps. Because they arent geared toward running high demand hydraulics like skidloaders are. Thats what they have a PTO for. Most tractor implements run off the PTO. But with 40hp at the PTO.....you can get up around 20GPM off a PTO pump @ 2500psi as long as you dont ALSO need the HP to drive the machine at the same time
Some PTO pumps also have a thru shaft. This PTO extension allows use of a PTO implement while leaving the pump in place, permanently.
Example, PTO pump to run a loader. Need to power an implement off the PTO and use the loader. It's a clumsy way of doing things, but works.
CT
/ how many GPM is needed #43
Pump flow:12 gpm
45.4 lpm
Total flow:17.5 gpm
66.2 lpm
For PTO and loader usage this should be your minimum. Anything less will probably disappoint you later on.
This is specs. on Workmaster 50, 4x4 with gear transmission and loader. (5.5 gpm of the Total flow is for power steering)
/ how many GPM is needed #44
There isn't one that I know of.
I agree. Essentially all the name-brand tractors will have adequate hydraulic flow to do whatever you may likely do with them. The main exception I know of is flow to support hydraulic motor driven things like a front end loader mounted brush cutter and anything hydraulic motor driven.
/ how many GPM is needed #45
Flow and pressure don't really vary all that much on similar sized tractors. The way it is calculated by the advertising dept. accounts for much of the variation. For instance, do they include power steering? At what RPM?
You can always mount a PTO-powered pump with a reservoir on the 3pt of any tractor.
I agree with LD1 when he says it's easy. You can do it yourself or if you want one already built, several companies sell a 3 pt mounted reservoir and PTO pump all ready to go with accessory outputs. You may not need 20 gpm at full pressure and may well end up just using the standard 50 hp tractor hydraulics - it costs nothing to try it that way and your tractor will probably surprise you.
If not, the cost of the complete 3pt high output pump and reservoir is in the under $4K range. Expensive, but not enough so to change what tractor you buy. I used to have one on a 33 hp tractor for running a big splitter with a Cat cylinder, and that PTO pump had huge flow and pressure with the tractor running half throttle.
rScotty
/ how many GPM is needed #46
Some tractors use cheap valves that won’t curl and lift at the same time. I’d be way more concerned about that vs hydraulic flow.
Disagree. It is not cheap valves, it is paying for (or not paying for) diverters or flow splitters. Nearly all tractors you might consider run open center hydraulics also known to me as "one track mind hydraulics." With open center whatever valve you open to do something inherently precludes other hydraulically powered activity from that same pump high pressure line. Most loaders (such as and including my own MF DL250 loader) will NOT curl and lift at the same time. Some tractors and loader valve configurations include a flow splitter or diverter that allows 2 things to be hyd driven at once but with less oomph. Most do not (though diverters/splitters may be more common as time goes on.)
The majority of utility tractors in the field today use loaders that are one track minded. And will NOT both curl and lift at the same exact time. There are many ways to obscure these facts and make the loaders (and other implements) APPEAR to do two driven things at once by using gravity as the other source. So usually you can dump while lifting, you can lift while dumping, etc. but only one hyd powered action at a time.
/ how many GPM is needed #47
A bigger concern to me is can I make my hydraulics work slow enough. The maximum flow rate has never been an issue, but if the controls don't work well at allowing you to establish a miniscule flow without being forced to use micrometer like movements, that's can be a problem at times.
/ how many GPM is needed #48
rScotty
1 thing not covered so far is return plumbing, on almost any of the CUT tractors if you are going to use a heavy motor on the hydraulics (some thing that requires RPMs to work like a brush mower not auger) you will need a dedicated return line.
/ how many GPM is needed #49
That's true, and since the pressure is low then most any hose will work. But to be smart about it, and use a hose rated for hydraulic oil so that you don't get particles. The fittings can be radiator hose clamp type, but when the additional return line intercepts the existing return line (you can run one into the other and combne flows if you then oversize the return hose from that point) and use a Y connector to avoid the back pressure you can get with a T connector.
rScotty
/ how many GPM is needed #52
Something also to think about is that your hydraulic pump, whatever its size, will exact a toll in fuel consumption in direct proportion to how much oil it moves at a given pressure. My HST Kubota B7510 uses more than twice the fuel of my Bolens G174 4WD manual when doing the same job. When running a 7.5 kw generator the difference is even more extreme, because the Bolens can loaf along in 2nd gear PTO and still run the house, but the Kubota can only rant along at 2500 rpm.
So the contrarian point of view asks how little hydraulic volume do you have to have for daily jobs with your tractor? My Bolens dumps its trailer and lifts implements just fine with 4 gal/minute, while the Kubota splits 8 g/m among power steering, the transmission, and auxiliary power to dump that same trailer. Mind you, with the pressure turned up to 2500 psi, it will dump a full load of gravel out of the trailer, a feat the other four tractors on my property, regardless of their size, cannot accomplish.
/ how many GPM is needed #53
Many years ago the company I worked for took specifications for a bid for a tractor loader backhoe. The township that wanted to purchase the hoe picked the one they wanted and wrote the specifications for that unit into the bid. Without them allowing for differences in the specifications only one brand dealer could submit bids. When I saw the bid they had specified such trivial things and you would have thought they were experts at designing a tlb.
Why do I bring all this up? Manufacturers build tractors to meet certain requirements yet keep efficiency and cost down. Most manufacturers equip tractor to handle most tasks the tractor is required to do. Some may even offer a larger pump. Most tractors are equipped with pumps large enough to operate a loader at a reasonable speed. Some manufacturers offer different size cylinders on the loader depending on the pump size on the tractor. Even others use a separate pump for the loader.
My thoughts are don't reengineer the tractor. Figure out what you want to do with the tractor and purchase one that meets your requirements. The tractor and any attachments should be engineered to work together, it is when you add third party or specialized equipment your requirements may be different.
  • Good Post
Reactions: JWR
/ how many GPM is needed #54
Both my M9's have 2 pumps mated together. One pump for the hydrostatic steering the other larger Pump for the hydraulics. Not sure what the GPM rating is but I've never ran out of hydraulic power.
/ how many GPM is needed #55
Extra hydraulic capacity in my opinion is usually a good thing, yes it will consume a little more fuel but when your short of hydraulic capacity it gets pretty expensive to resolve that issue.
/ how many GPM is needed #56
You make it sound as if there is a real world difference between 8.8gpm and 9.1gpm. so much so that it should be a key factor in picking a tractor brand.
If you need more flow.....get s bigger tractor....get a pto driven implement....or get a pto pump.
With so little difference in GPM among similar sized machines.....it's not even on my radar when comparing tractors.
And if you need 20gpm.....a 50hp tractor with a 20gpm PTO pump is alot cheaper than a 100hp tractor
That similar sized pump total output does seem to be the norm on new under 60 HP machines,
but as an example on older tractors, my 1967 Ford 3000 tractor ~40 HP
had a 16+ GPM crank driven pump (FEL) a 5 GPM power steering pump, a ~5 GPM rockshaft 3point pump and an SOS trans pump only 40 HP and about 26 GPM total not counting the select o speed transmissions pump.
My 55hp rhino tractor has 11 GPM for FEL/ PB remotes, 5 GPM pump for steering , and a scotch yoke 5 GPM pump for the 3 point so 21 GPM total.
I am a fan of individual pumps for function. With them no loss of loader function when steering is worked hard or loss of 3 point either. Seems like all of the under 60HP new tractors have maybe 2 pumps. Jmo, I don't think that is an improvement other than maybe ease of service.
Same for removing FEL bracing to the front and rear axle mounting points... engine access is easier and making a prettier tractor, But not as strong when pushing FEL capabilities.
For the OP yeah why not add a PTO pump if he wants /needs it.
/ how many GPM is needed #57
I am speaking in terms of late model tractors. Things made in the last two decades. Not 1960's and 1970's machines.
Alot of older machines ran alot higher GPM, but at a lower pressure. And to compensate they used alot larger cylinders (or alot longer stroke and had geometry to maximize lift capacity at lower PSI)
Trying to compare a 1970's machine and crank mounted loader pump to a modern tractor of similar HP is apples to oranges comparison.
Speaking of late model 40-50HP machines, like deere 4-series, kubota MX or GrandL series, or similar machines from any make.....you will find real similar specs for available implement flow and pressure. Usually between 8 and 10gpm
/ how many GPM is needed #58
Decide what you need to run, find out the GPM and PSI required. You will likely only use one at a time.
The 'rule of my thumb' is go big so you can easlily operate a Splitter, mower etc.
/ how many GPM is needed #59
No argument, I agree more the same than different.
Given a choice though, not sure the new machines with 2 pumps or less is superior or a real "advancement". if I buy a new tractor if given a choice between a single pump for everything, or a tractor with a steering pump, FEL pump and separate 3 point pump... all else being equal I would chose the tractor the multiple pump design.
Looking at some new machines,
The 2850M Massey has a bit better hydraulic flow specs than the average ~36 PTO HP CUT with 7.0 gallons for steering and 12.6 for FEL /implements. so 19.6 GPM total.
/ how many GPM is needed #60
My Kubota M59 TLB has 16gpm. Like the large and quick aloader for that size machine. Two pumps for the backhoe helps moving large cylinders.
Do use a hydraulic pole chainsaw motor.
While it might run some hydraulic mowers I think it is not really set up to handle the heat load of continuous operations. Tractors built for hydraulic mowing have added front and/or pto pumps, tanks and coolers.
Large Hydraulic motors usually require an always open path back to tank to allow hydraulic motors to coast to a stop and a case drain like on skidsteers.
Usually a significant step up in cost to get high flow in tractors.
1996 International 4800 Bucket Truck, VIN # 1HTSEAAN6TH399113 (A65563)
1996 International...
1996 Chevrolet Astro Cargo Van (A64194)
1996 Chevrolet...
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
2019 Chevrolet Tahoe SUV (A64194)
2019 Chevrolet...
John Deere 3010 Tractor (A66408)
John Deere 3010...
2021 ASV RT-120 FORESTRY SKID STEER (A65053)
2021 ASV RT-120...
