After rain B7800 will not run?
/ After rain B7800 will not run? #1
Rob 80
WVA
B2650
Tractor was working fine we had a large amount of rain since the last time i used it. The tractor will start but die in a min with a lot of black smoke leave it sit for awhile and it will start again but die in a min.
It cranks fine just refuses to start. I took some of the fuel out thinking maybe water got in somehow.
I'm not sure what to do besides drain the fuel and try new the tank is mostly empty, i have also tried leaving the gas cap off.
/ After rain B7800 will not run? #2
I have a b7800, I am thinking they have a fuel shutoff solenoid that I would check. Loose wire or bad solenoid. Just a thought
/ After rain B7800 will not run? #4
Black smoke usually means a rich mixture. Check the air filter to see if it got wet.
