Need help with purchase of weight distribution hitch
   / Need help with purchase of weight distribution hitch #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I need help buying a weight distribution hitch. I don't tow much anymore but do tow 10,000 lbs every now and then with a 10,200 lb max rated vehicle. Usually I haul 7500 lbs for trips up to 50 miles. My neighbor has convinced me I should have a weight distributing hitch but, which one?
After searching I am more confused so I come to the smarter guys here to point me in a direction. Here's a couple I've looked at, mostly because I like their brand name on other things.
Thank you. Any help or advice appreciated.
   / Need help with purchase of weight distribution hitch #2
I always figured if I need on I’d try an Anderson. No personal experience though.
   / Need help with purchase of weight distribution hitch #3
I am not a fan of the round arm style, you loose ground clearance. I prefer the trunnion style. It may or may not matter in your use, I do a lot of off highway hauling.
This is the one I have. It may be too heavy for your use, they make them in the 10k range.
https://www.etrailer.com/Weight-Distribution-Hitch/CURT/C17333.html
   / Need help with purchase of weight distribution hitch #5
Over on the RV forums, the Anderson seems to have a bad rep for heavy tows (i.e, 10,000). Seems well received for lower weights though.
   / Need help with purchase of weight distribution hitch #6
I've got a Curt setup, but for a lesser weight rating than 10-14K. They work well and do the job nicely for the trailer I pull. You definitely will have a better towing experience with a WD hitch vs without. I do like the trunnion style, but when I was buying, they were more expensive.
   / Need help with purchase of weight distribution hitch #7
I only tow a few times a year but when i do it's a full load down (~8K+) to Mississippi and empty coming back to Va.
I went with an Equal-i-zer hitch.
It's really easy to hook up the second time. The first time I had to fiddle around a bit to get it just right.
   / Need help with purchase of weight distribution hitch #8
That looks pretty nice. So it’s basically quick to put on and take off?
Yes, easy on, easy off. Make sure your trailer tongue is compatible with the over center lift brackets. Also, bar length. Mine is the short bar style to clear the trailer tool box. Keep in mind your truck and trailer height, to insure the right amount of hitch drop/rise.
Good advice that I don't fully understand but will measure today and start figuring things out. One trailer is an 18 ft HD hauler and the other is a 12 ft HD dump.
   / Need help with purchase of weight distribution hitch #10
you never said what you are towing with?
I've had a lot of trucks and towed a lot of trailers. Never had a weight distribution hitch.
Always had Air Lift air overloads. adjusted the truck height till it was back up where it was without the trailer.
never a issue.
never a issue.
Toyota Tundra, 10,200 max trailer weight.
   / Need help with purchase of weight distribution hitch #12
never a issue.
The thing is even with your air overload system. if the vehicle manufacturer required weight distribution above a certain amount, or the hitch required weight distribution above a certain amount then not using it can get you into some hot water if you are involved in an accident. Some of the new pickup trucks have a 1500 tongue weight 15000 pound towing capacity without weight distributor. But most require weight distribution legally above 500-600 pound tongue weight or 5000-6000 trailer weight. And add on items don't override the manufacturer ratings.
   / Need help with purchase of weight distribution hitch #13
How would you use weight distribution with this combo? Pretty sure he is at max GCW and pulling bumper pull doubles. I would not like this at all, however, it appears to be the norm for Custom Combiners.
   / Need help with purchase of weight distribution hitch #15
Nick,
When harvest starts, I’ll get some pictures for you. When the header is placed on the trailer, it puts almost all of the weight directly over the axles. There are sliding brackets that allow for some adjustment. Some weight does get transferred to the dolly, but no hitch weight is added. They work really well for what they are designed for.
Bud
   / Need help with purchase of weight distribution hitch #16
Nick,
Bud
Thanks Bud, I would like that. I do understand the trailer is mostly used behind the combine or behind a big truck and trailer. However, they do pull it with a pickup and in the case of the double tow, he is probably at max gcw. That was why I questioned RandyT ...weight distribution is "Required for max GCW"
   / Need help with purchase of weight distribution hitch #17
Can't run weight distribution on that but in most states are governed by a whole different set of rules. Limited to 20 mph in some states, and even falls under CDL A with double/triple trailer endorsement in some cases. And that fuel trailer can carry a totally different dimension of the equation.(Hazmat, placard load)
   / Need help with purchase of weight distribution hitch #18
I don't think that load weighs all that much, combine headers are lots of relatively thin sheetmetal and obviously that dolly tongue puts very little hitch weight on the tow vehicle. What it will require is a decent load or ballast in the truck bed.
   / Need help with purchase of weight distribution hitch #19
I second the Equal-i-zer system, I have a 14k one for our 30' Toyhauler.
   / Need help with purchase of weight distribution hitch #20
Even if the fuel tanker trailer is half empty, the combo might weigh 15k. The header trailer is considered a farm trailer, so brakes are optional. Even if it has brakes, for sure there is no plug on the rear for the double. Looks sketchy at best and a hand full at worst. I am no stranger to heavy loads on rough off highway hauling, but for some reason that goofy load behind an empty pickup truck drives me crazy:D
I am plumb fine with this style header trailer.
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
