Marking your tools
/ Marking your tools #21
S
not sure what u r referring to here, but i am thinking a “pen” that has acid in it and u simply write on metal. It leaves a dark stain. Cant be wiped off.
Got any brand suggestions?
Thanks,
Peter
/ Marking your tools #22
I think I can truly say that I have never lost a tool to anyone's hand but my own. If y'all are losing tools like that maybe security cameras are a better investment.
/ Marking your tools #23
Easy way is to take a grinder/cut off wheel & put 1, 2, or 3, notches on the handle, head, grip - whatever. Doesn't take much - just make sure your friends don't use the same number of notches!
/ Marking your tools #25
Thanks,
Peter
Can’t recall what exactly i had, but here are 2 examples of them
/ Marking your tools #26
I use green electrician's tape.
/ Marking your tools #27
I mark mine as the ones behind the lock.
/ Marking your tools #28
We haul many a tools into the field to clear trails and like to mark them with our name and phone number via permanent markers. This isn't for thieves but for when people simply find them out there so they can text or call us. You wouldn't believe how many we've got back that way. At home they're stored in a unlocked garage..
/ Marking your tools #29
…. At home they're stored in a unlocked garage..
Are you the guy who leaves his keys in the cars too? Aryl’s house at 3AM boys!!
/ Marking your tools #30
I HATE people like you!!!! :D A couple of years ago I came out of the grocery store and noticed a bank envelope behind my truck which didn't look empty. I picked it up and there was $50 CASH!!!! I looked again and there was a withdrawal slip with the bank and account #. 👎 :(
I dropped it off at the local PD/Firestation, where they were glad to take care of returning it back to the rightful owner.
/ Marking your tools #31
The sharpie corporation makes different grades of marking pens and we use the most durable grade in black and silver colors. We also put blue and white vinyl tape on tools to make them more visible while in the field.
/ Marking your tools #32
I like painting the handles bright yellow. They are easy to see in the grass.
/ Marking your tools #34
We don't use yellow due to fall colors. Blue is a color that rarely happens in nature.
It disappears easily in snow conditions, however. We've gotten away from using blue flagging because it's difficult to see against the green background in summer; and in winter often is hard to see when the sun is on the snow.
/ Marking your tools #35
So now I'm curious what colors do you find useful?
All the best,
Peter
/ Marking your tools #36
Marking them so I can recognize them is not my issue I like my tools marked so at a glance other people can recognize is not theirs I don't think I have a problem with people stealing them its just them accidently getting mixed up when working with someone else so bright spray paint all over not a little dot or initials it has to be something you can't miss
/ Marking your tools #37
And that why we write oue name and cell number on them. We've got most back when found.
/ Marking your tools #38
Here is some blue weights that are easily found when dropped in snow. 😅
/ Marking your tools #39
All the best,
Peter
We use day glo flagging. Forest Arctic Vinyl Flagging
A lot of people use orange, although I prefer the pink. It doesn't blend with the leaves in fall as easily; but mainly because in years past it didn't fade the way that orange tended to do. Sometimes I will use pink and blue together, for flagging areas such as streams where the harvester operator needs to know where they are.
/ Marking your tools #40
I started sand blasting and oiling all my tools. No one else did it and even if you paint colour on it or engrave it you can't hide the blasted finish.
James
Sterling 9500 (A63118)
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
2017 TROXELL 130 BBL VACUUM TRAILER (A63569)
2017 TROXELL 130...
