LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,898
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Could'nt tell you on a 105C but many that used different shafts for the 540 and 1000 the shafts will engage different drive gears in the pto housing.
Many will have a large snap ring holding the shaft in just removing the snap ring and swapping the shafts got the correct gearing selected for the shaft splines, 540 rpm being a 6 spline 1 3/8" shaft and 1000 rpm being a 21 spline 1 3/8 shaft.
Many tractors with the electro hydraulic 4wd activation turn it on when both brake pedals are depressed together, just using one brake pedal it usually does not engage. I'm surprised it comes on when turning. Nice to have when parking also. I wonder if that one functions like some of the older IH's that actually used hydraulics to disengage the 4wd clutch pak. I always liked that system as it holds better in park and a failure will have you in 4wd rather then 2wd.
