Groundsmaster 52 runs 10 minutes, then dies
/ Groundsmaster 52 runs 10 minutes, then dies
I have just ordered a new OEM Briggs carb kit to be installed in a few days once it arrives. In the meantime, I do appreciate the many good suggestions for what is going on with this old B&S 16 hp L head cast iron engine, horizontal shaft. It’s true monster of an engine, but has tons of torque when running properly. To all who suggest replacing the condenser, it was the first thing I did before anything else. So, for now I’m ruling that out, unless every other suggestion proves fruitless as well. Then will try a second new condenser.
As for the fuel filter, as mentioned above, I have replaced it with what is recommended in the parts manual, using a metal filter about 1.5“ X 2.5” not counting the inlet & outlet tubes. It has an arrow showing the correct direction of flow. Gasoline flows readily through it. As for the little screens mentioned…I haven’t found any other than the two elbow fittings at the bottom of the tank. I couldn’t see inside the tank to tell whether or not they have screens on them, but maybe. Whether they do or not, gasoline flows freely from the elbows when the hoses are pulled.
If you haven’t seen the carb on these engines, it is a two piece carb, with the intake air entering at the top, but then diverted 90 degrees into the carburetor. This carb also has a Welch plug at the rear of it, about the size of a frost plug on a liquid cooled engine. The high speed needle/jet faces downward at an angle of about 50 degrees. The low speed needle/jet sits horizontally at the top of the carb. The float needle is independent of both, and is only accessible by disassembling the carb. So, here’s a strange observation. Normally, the float needle seats in a removable brass fitting. On this carb, none was present. Huh? Well, it wasn’t in there and the engine had been running fine, so this remains somewhat of a puzzle. How can a steel needle seat into pot metal? I will be putting on my magnifier hood this time around, to inspect that mystery more closely. With the kit not yet here, I don’t know if I will discover a brass seat included or not. If I do, then someone has been in there before and didn’t put it back in. But, if that were true, how would the engine run fine for many years without any issues. Also, how could a needle seat perfectly in molded pot metal without allowing the fuel bowl to overfill and leak? Soaking the carb to clean it properly, then replacing all replaceable parts with new should remove the carb from the suspect list of what is causing the problem. With any luck, it will fix the problem!
The other mystery is the appearance of blue smoke from the muffler when quickly opening the man butterfly valve. Usually, the engine responds by instantly increasing rpms. Right now, it sputters a bit, increases in rpm less instantly, and smokes a bit more than lightly until the engine rpms return to idle, at which time there is no smoke. Perhaps the smoke is from an ounce or two of Seafoam I added to one gallon of fuel. Oh, the fuel is 91 octane non-oxygenated fuel, containing zero ethanol. I have typically used this same fuel for nearly 40 years in this tractor without any problems before. Plus, it’s $5.19 per gallon, a dollar more than garden variety E10 which contains 10% ethanol.
As mentioned, I didn’t unscrew the port on the engine block where the pulse/vacuum line to the fuel pump is connected. The pulse line, according to the service manual, is supposed to be looped around the dip stick tube. It currently is not, but when I replaced the original Walbro 3000 all metal fuel pump with the new Walbro 3000 plastic pump, I made a new bracket so as to raise the pump about 5” above where the original pump was mounted. I did this to make sure the pump was mounted higher than the port on the block where the pulse line connects, as this is recommended in the manual to prevent oil from draining out of the engine block and working by gravity to the fuel pump through the pulse/vacuum line. If this happens, evidently problems occur, although the manual didn’t describe what those would be. I suspect extra oil into the pump, then mixed with gasoline on the way to the carb, ultimately ending up with issues similar to what I am experiencing. But, that’s just my guess as to what happens.
At this point, my focus will be on making sure the fuel system is working as it should. If that doesn’t yield positive results, then the electrical system will be next, with the coil being in the bullseye. As I mentioned before, it’s last on my list due to where it is located. It’s located above the flywheel which is accessible ONLY by pulling the engine from the tractor. On the Groundsmaster 52, this means removing the seat, the entire top cover of the chassis, the fuel tank again, followed by disconnecting the driveshaft, then using the engine crane (did I mention this is a heavy cast iron beast?) to lift the engine out after removing the engine mounts. Truth be told, it’s not a small task, so it’s dead last on the list of possibilities to check off as to what is causing the problem. I’ve been down that route twice before when the doggone Welch plug fell out of the carburetor and allowed dirt to be sucked into the engine, resulting in a rebore the first time and an entire new short block the second time. That was over 1000 hours ago, after we JB Welded the Welch plug in after the second disaster. I have one more re-bore possible on the second short block, but I’m hoping that is another 500 hours away.
Well, that’s where it stands today. Hope to have the carb kit installed by week’s end, and will report what the results are. Again, many thanks to everyone for all the great suggestions, some already implemented, some not yet. I’m waiting on a spark tester yet, too, as that suggestion was well taken and will be tried in due time.
Vvm
/ Groundsmaster 52 runs 10 minutes, then dies #42
One thing I’d try is this, if you haven’t already.
You say the engine starts to die, but if you choke it, it starts to run better.
Have you tried shutting the throttle down to idle? That would lessen the demand for fuel. If the engine starts to run normally at idle, then you power it up and it starts to die again, you kinda know it’s all fuel related.
Choking shuts off air to the mixture.
Throttling back decreases the demand for air.
Same effect yet at different RPMs.
/ Groundsmaster 52 runs 10 minutes, then dies #43
For those that have never seen a Toro Groundsmaster 52 front deck mower:
Pictures from an image search.
/ Groundsmaster 52 runs 10 minutes, then dies #44
Neat little machine. I’m a big fan of out-front mowers.
/ Groundsmaster 52 runs 10 minutes, then dies #45
If the fuel pump is like what Rotax uses on some engines it is a diaphragm with fuel on one side and engine vacuum pulses on the other side. In the case of Rotax, the pulse line is connected to the crankcase and the piston moving up and down causes the pulsing which causes the diaphragm to move back and forth. A couple of reed valves on the fuel side cause it to be pumped through to the carb. The issue with having the pump above the crankcase fitting is to make sure any splashed oil drains back into the engine and out of the pump. If the pump gets swamped with oil it will reduce or completely cut off the ability of the diaphragm to move. Rotax solved this problem by drilling a little tiny weep hole in the housing on the vacuum side of the diaphragm with instructions to make sure the pump is mounted with the hole pointed down. Any accumulated oil or condensation will drain out the weep hole.
That is a mower and engine worth preserving. Good luck with your issue.
/ Groundsmaster 52 runs 10 minutes, then dies #46
The needle and seat is odd. Both being steel. Worst case, it wouldn't seat well and engine would run rich, or at least gas would fill the elbow to air cleaner. This came on suddenly I guess.
Does the needle have a point on it as it should? Or did the rubber tip on the needle disappear? On most old B&S carbs the rubber is the Seat. With a pointy steel Needle.
Blue smoke indicates burning oil. MAYBE. the rubber Seat or Needle tip is gone and you are getting gas into the Crank. Check your oil level. Smell the oil for a gassy smell.
/ Groundsmaster 52 runs 10 minutes, then dies #47
I was told to never run E10or any ethanol blend in older equipment, I only run Premium in my power equipment including a 1970 rototiller.
We do not have E fuel here in panama but remember back in Canada some people would wash the fuel to get it out for mowers and chainsaws. To wash get a clear jug, those 5 gallon water jugs for sale at grocery stores are good. Drink water or water plants. Put 4 gallons of gas in jug and a cup of water. Mix the best you can for a minute and let settle and the water will absorb the alcohol . Siphon the clean gas off the top.
Don’t know why I didn’t think to mention this before, but you are correct….throttling it down and it purrs like a kitten for as long as I want it to. Throttle it up and it runs rough, seems starved. No backfiring. This is consistent with wife’s observation that if she stopped forward motion while mowing, the engine would restore itself to normal operating speed again until attempting to move ahead. The air cleaner is not plugged, and is nice and clean. How being fuel starved would lead to some blue smoke is unclear to me. As mentioned above, I added an ounce or two of Seafoam yesterday when I put one gallon of fresh fuel into an empty tank. I have had additives cause smoke before on other engines when the additives were in an excessive quantity, so maybe that. There is no black smoke at any time, as one would expect from a rich fuel mixture.
That’s new information for me. Never heard of “washing” gasoline before. Thanks for sharing the know-how.
/ Groundsmaster 52 runs 10 minutes, then dies #50
Volvoman, I just fixed a briggs motor that was doing the same thing. Some briggs motors have a spring loaded fuel shut off valve that shuts off the fuel when you shut the key off to keep it from backfiring when you turn the key off. It is a round insert that goes directly into the carb. there is a spring loaded needle valve inside that has a wire lead to it. if that wire breaks or the 12 volt is interrupted ti will shut off most of the fuel. My teck expert told me to unscrew the valve housing and cut the needle off. That saved me $50 for a replacement.
Sounds like something on a later Briggs. My Groundsmaster 52 was made in 1980, when flathead (L-head) engines were the norm for lawn mowers and garden tractors. Was the engine you just fixed an OHV engine?
/ Groundsmaster 52 runs 10 minutes, then dies #52
/ Groundsmaster 52 runs 10 minutes, then dies #53
I have a problem with a old Craftmans tow behind grass vacuum. Just sucks up the grass clippings from the riding mower. I found that inside the carburator there is a neddle valve that gets clogged with dirt, starving the engine of gas. I had to remove the neddle valve and clean all the dirt and gunk out. Runs fine after the cleaning, or maybe get a replacement carb?
/ Groundsmaster 52 runs 10 minutes, then dies #54
In your current situation, gas with ethanol causing your current problems is a red herring. You’ve drained the tank and flushed the fuel system with fresh gas.
Yes, the problem now exists with fresh non-oxygenated gasoline. If I was a betting person, I would place my money on the problem being inside the carburetor somewhere. I have considerable experience with Kohler engine carbs, but not much with those used by Briggs. So, I can’t say one way or another which tend to be more finicky. This carb has been performing very well for over 40 years, so I can’t say it isn’t a quality carb. But, I do know that over the past 40 years fuel quality is definitely different than it was back in 1980, and carbs tend to accumulate varnish deposits far more quickly than before, thereby causing more fuel related issues now than before.
/ Groundsmaster 52 runs 10 minutes, then dies #56
had a similar issue on a forklift, ran great for a short period and died, fuel bowel empty so installed a electric pump, similar issue so I emptied the tank, used a shopvac with a 3/4 plastic hose to vacuum the tank bottom, lots of junk and refilled, to my surprise same issue, turned out the pickup tube had a bug or seed in it, idle it was sitting there but full rpm it sucked up the tube and stuck at the 90 elbow starving gas, shut down it sank to the bottom of tube
check the pickup line
By “pickup” line, are you referring to the line from the tank to the fuel filter, or the line between the filter and the carburetor? I have already replaced them both with new on the GM after flushing out the tank with a high pressure washer for several minutes. As for the bug…it served as a floating check valve, something that I had suspected was occurring in the GM’s system too, but after replacing the lines and cleaning the carb, I am 99% sure there isn’t anything like that going on here. It IS what happened to me in the past once, on the old Studie that Ii described above.
/ Groundsmaster 52 runs 10 minutes, then dies #58
I believe you are on the right path in ordering the OEM carb rebuild kit but while waiting for it,you might clear up a couple of things. Seafoam doesn't make smoke, especially in maintenance dose of 2-3 oz per gallon. The blue smoke coupled with finding out there's a pulse fuel pump involved points to a possible problem. Oil can leak through a pinhole of failing diaphragm. "IF" diaphragm has a pinhole that would cause fuel starvation "AND" account for blue smoke. I believe you are aware of this but a word of caution anyhow. If fuel pump is the problem,odds are there's gas in the crankcase so keep that in mind or you might have to use that last overbore sooner than expected. One way of testing this theory is disconnect pulse hose,connect a temporary fuel tank that is higher than carb and watch for fuel drip from where pulse hose connects to pump. Dripping gas makes it a certainty of failed pump diaphragm. If there's no drip,start engine to see if it still boggs when deck is engaged.
I'm not suggesting a problem with condenser but want to say something about condensers in general. IMO condensers are one of the most difficult problems to nail down. NEVER throw old condensers away,have them professionally tested then label and save for future use. Everyone complains about quality of products manufactured today and condensers are at the top of the list. It isn't uncommon to have an engine run poorly,not start or intermittently run rough after a routine tune up,becasue new condenser is bad.
/ Groundsmaster 52 runs 10 minutes, then dies #59
my recommendation when it dies open the drain on the carb bowl, is it empty or full? those impulse pumps are not great with age and the ethanol gas, pick up a cheapo electric and try it again, had a issue with a mule where the float shutoff pin the center should be spring loaded but it was stuck in the out position, freeing the pin corrected the low fuel level in the bowl
on my machines I have switched to the electric pumps, way easier to check
/ Groundsmaster 52 runs 10 minutes, then dies #60
Great post. However this only works if the pulse line does not have a loop that can cause oil to collect in the pulse line. The pulse line must NOT have a loop between the pump and the pulse port. In other words, the pulse line MUST be all down hill from the pump.
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A59823)
2017 KALMAR OTTAWA...
2005 Isuzu NQR 4 door box truck with folding gate (A61307)
2005 Isuzu NQR 4...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
SKLP 100YG Pipe Crimping Machine (A60463)
SKLP 100YG Pipe...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
