3510i Steering Cylinder Leaking
/ 3510i Steering Cylinder Leaking #1
cpocobb
Ga
Branson 3510
The steering cylinder on my 350i is leaking (pouring) on the right hand (from the seat) end, and I’m about to replace the seals. I haven’t gotten the seal kit yet - $265+ for o-rings and seals - and I’m wondering if anyone has done this before? There doesn’t appear to be a threaded end on the cylinder, so I’m wondering what keeps the hydraulic pressure from simply pushing everything out the end of the cylinder? My book doesn’t show a breakdown of the cylinder and I can’t find one online, so I’m in the dark as to what to expect.
/ 3510i Steering Cylinder Leaking #2
I just had my cylinder rebuilt and all the power steering lines replaced including one loader line for 300 even. I think there are c clips on each end that hold metal retainer in place the the seal will slide out.
/ 3510i Steering Cylinder Leaking #3
it's hard to see but there is a little clip on the insides. its just a round circle clip. you pull that out then push the cylinder that way and it will come out.
Thanks! I don’t have the cylinder off the tractor yet, so I haven’t cleaned it up much. Did a Branson dealer rebuild it, or an independent shop? Just a seal kit from Branson for mine is $$$$. If an independent shop can source the parts from somewhere else, I’ll definitely go that route.
/ 3510i Steering Cylinder Leaking #5
It was just a local hydraulic shop. Most of them should be able to do it though.
/ 3510i Steering Cylinder Leaking #6
Make sure its a good hyd shop, I got burned on our rebuild by some so called expert:mad:
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2014 Toyota Tacoma Ranch Camper Shell (A64126)
2014 Toyota Tacoma...
JOHN DEERE HX14 ROTARY MOWER, 3PT (A64278)
JOHN DEERE HX14...
Craftsman 16in Variable Speed Scroll Saw (A64553)
Craftsman 16in...
More info coming soon. (A64557)
More info coming...
2015 Mack GU713 T/A Wet Kit Day Cab Truck Tractor (A64556)
2015 Mack GU713...
