Clean up after pine thinning?
/ Clean up after pine thinning? #1
ssramage
Ford 1715
Forgive me for a dumb question. I just picked up my first tractor (a Ford 1715 - no FEL). It will work for the majority of the hunting club work I have here in Southeast GA, but a recent pine thinning around one of my better stands has left me with some clean up work to do. I have sticks/debris all over my trail in and food plot area that need to be cleaned up so that I have bare dirt to disc up to plant and a clear path to drive to the stand.
Total area to clear is probably a 200 yd trail in, and an L shaped area in the pines where my plot is.
Would a landscape rake work in this instance? I have a line on a 6' rake for a reasonable price, or could rent one locally.
If not, other recommendations?
/ Clean up after pine thinning? #2
Yes a landscape rake is a good tool or a pine straw rake could work too, if they are too big or heavy pieces
/ Clean up after pine thinning? #3
Yes a landscape rake will work well. If you remove every other tine it will work alot better. When every time is in the rake they clog up quick and act like a back blade or just glide over the stuff your trying to remove.
Adding a 100lb suitcase weight to the pivot will help too.
/ Clean up after pine thinning? #4
Here is the best option: Pine Needle Rakes | Pine Straw Rakes | Prepare Pine Needles For Baling with the Everything Attachments Pine Needle Rake 72" Length
2015 Komatsu HM400 (A61166)
2015 Komatsu HM400...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
Goosen Bale Chopper Hay Blower (A61166)
Goosen Bale...
