3 point hitch
/ 3 point hitch #1
Hambone
Southeast Kentucky
JD3032
Hey Everyone,
I could use a little help, I think.
I am having issue with hitch not lining up right. I looked at it for a while and just couldn't figure it out.
I might walk out again and it hit me in the face, you all know how that goes.
It looks like everything is in a bind, not straight
Let me know if you need more pictures.
Any help appreciated 20220714_120744.jpg20220714_120713.jpg20220714_120718.jpg20220714_120738.jpg20220714_120753.jpg
/ 3 point hitch #2
I just went out and looked at mine. I was focused on the adjustable link on the right side. I thought your looked bent and cocked to one side. Mine looks identical. I don’t see anything obviously wrong.
/ 3 point hitch
See the top of left arm, cocked real bad.
Well it is pulling the lift arm that goes into top of case, then breaks of the bracket that goes to the MMM
/ 3 point hitch #5
Looks like the swivel is not "swiveling". Needs some penetrating oil or lube.
/ 3 point hitch #7
Fwiw - I keep a spray can of WD40 with the tractor. I spray everything that moves, rolls, hooks together with it before attaching anything. Really makes it much easier.
/ 3 point hitch
Here is mine. It does look like the swivel might be in a bind.
View attachment 754180View attachment 754181
Loos pretty similar to mine, thanks for posting!
So now I have to figure out why it is pulling the top link off the shaft at housing.
I have replaced snap ring twice, and that link for mmm is $135
UGH.
To be honest, IMO, the 2210 I had for 18 years was a better thought out machine than this one.
Thanks for thoughts!
/ 3 point hitch #9
As an experiment why don't you reverse your bottom arms/ flip/shift etc. Just to see if there is better alignment. The end configuration of the draft arms maybe mirrored though. I know Dodge Man's picture aligns with you set up. But just maybe the dealer install instructions were wrong or were not followed. Also check for binding/ full range/ if the new set up aligns better. Just a thought.
/ 3 point hitch #10
I’ve also seen the advice of turning them around, making the front the back so to speak. I’ve never looked to see if that makes a difference. I use my 3 point but not a lot. I’ve got 300 hours on mine and maybe 40 hours of that using the 3 point but I’ve never had a problem. I keep seeing a reference to the mid mount mower, which is tied to the 3 point. I’m starting to wonder if that’s the problem.
/ 3 point hitch
Thanks guys.
Well here is what I did
I bought a 3032E yesterday. used, but only had 51 hours, also picked up a X330 to cut my grass.
So will sell the 2025
/ 3 point hitch #12
Modern problems require modern solutions, enjoy the new toys!
[EDIT]: We expect pictures.
/ 3 point hitch #13
Well that doesn’t work for me, get out there and fix that 2025r!:) Sounds like you got a couple of new toys, congrats.
/ 3 point hitch #14
I have a mid mount mower with the 3 pt lift. I will get you a picture of my set up. It John Deere design.
/ 3 point hitch #16
Good time to sell too; well, it is here, hopefully the same holds true in Kentucky. I sold my 1025R for more than I paid for it 3 years ago. 😂
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
2019 GALYEAN...
2013 TEREX USA LLC LIGHT TOWER (A60736)
2013 TEREX USA LLC...
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
STORAGE FEES (A59906)
