bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,531
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
This is a very minor issue but I thought I'd post to see if others have noticed this noise.
I've got 125 hours on my L6060 and I'm now noticing a noise which I can only describe as "gear clatter". It's not a binding or grinding sound, more like gears with a little play between the teeth. It happens only when at operating temperature in hot weather while rolling over uneven ground. It occurs in all gears and both high & low hydraulic ranges. Engaging the differential lock & FWD makes no difference. It isn't loud or even annoying but it is noticeable over the usual HST "whine". The factory SUDT2 fluid is clean and at the proper level. All maintenance has been done per the manual. It came on slowly after around 100 hours but doesn't seem to be getting louder. This relatively minor noise has no effect on tractor performance at all.
I've owned 7 Kubotas over the years, 6 of which were HST's, and they all make noise but this is a new one. I'm hoping this is the result of normal gear wear coupled with the very thin SUDT2 fluid under high operating temperature. This tractor is also the first cabbed machine I've owned. It's possible the noise is more noticeable inside the cab and probably wouldn't be detected on an open station machine.
Has anyone else noticed this?
