JD 345 Snowblower
/ JD 345 Snowblower #1
TimberHole
Missouri
JD9504WD w/ 75 Loader, JD345, Bobcat S150
I have a JD345 and tonight I bought a 42” snowblower M03252X221750 and a 48” blade M03480X040082. Can anyone confirm these are the correct attachments for my 345? They came off a 325 so I think they will work. I didn’t get the front lift kit with them but I’m going to call the guy and see if I can get it. If not I will be looking for a lift kit.
/ JD 345 Snowblower #2
I had a 325. Those are correct for your tractor.
The lift kit is available and can be looked up on the Deere parts website.
/ JD 345 Snowblower #3
I have a John Deere GX345 and can confirm that snowblower is correct for your unit.
/ JD 345 Snowblower
Do you use a snowblower on yours? If so, how does it do?
/ JD 345 Snowblower #5
Yes, I do use a snowblower on my GX345. The power steering and hydraulic lift will make life much easier when using the blower. Also - I would recommend that you do a web search of modifying the snowblower using 2 pieces of belting that measure 3" x 5" x 3/8" thick. When these are mounted on the auger - it greatly enhances the blowing of wet snow and practically makes it impossible to clog.
/ JD 345 Snowblower
Thanks for the tip on the mod. I will do that before winter. Also ran across a video where a guy had added electric actuators and LED lights to the blower. I like those mods too! :) The guy I bought it from has said he will give me the front lift kit off his mower as I still need that.
/ JD 345 Snowblower
Can anyone provide a photo of the belt tensioner mechanism for this blower? Here is a pic of the tensioner on mine but I feel like it’s missing something as I don’t see how it would work as is. I cannot find a parts diagram online for this unit. If anyone has a manual or can point me to a parts diagram I would appreciate it.
/ JD 345 Snowblower
/ JD 345 Snowblower #10
Search the Deere parts website for 42 Inch Snow Thrower. It's there. There are two serial number breaks for the 42 Thrower.
/ JD 345 Snowblower #11
Did you look at the links ?? Apparently not. There are two different snowblowers for different s/n 345's. Suspect you have the later model 345.
/ JD 345 Snowblower
Sorry, I I thought the links were for the mower. That is the correct diagram. Thank you for the help. Not sure why I couldn’t find that as I use the JD parts site frequently. Looks like I’m missing a spring. Thanks again!
