JD 345 Snowblower
/ JD 345 Snowblower #1
TimberHole
Missouri
JD9504WD w/ 75 Loader, JD345, Bobcat S150
I have a JD345 and tonight I bought a 42” snowblower M03252X221750 and a 48” blade M03480X040082. Can anyone confirm these are the correct attachments for my 345? They came off a 325 so I think they will work. I didn’t get the front lift kit with them but I’m going to call the guy and see if I can get it. If not I will be looking for a lift kit.
/ JD 345 Snowblower #2
I had a 325. Those are correct for your tractor.
The lift kit is available and can be looked up on the Deere parts website.
/ JD 345 Snowblower #3
I have a John Deere GX345 and can confirm that snowblower is correct for your unit.
/ JD 345 Snowblower
Do you use a snowblower on yours? If so, how does it do?
/ JD 345 Snowblower #5
Yes, I do use a snowblower on my GX345. The power steering and hydraulic lift will make life much easier when using the blower. Also - I would recommend that you do a web search of modifying the snowblower using 2 pieces of belting that measure 3" x 5" x 3/8" thick. When these are mounted on the auger - it greatly enhances the blowing of wet snow and practically makes it impossible to clog.
/ JD 345 Snowblower
Thanks for the tip on the mod. I will do that before winter. Also ran across a video where a guy had added electric actuators and LED lights to the blower. I like those mods too! :) The guy I bought it from has said he will give me the front lift kit off his mower as I still need that.
/ JD 345 Snowblower
Can anyone provide a photo of the belt tensioner mechanism for this blower? Here is a pic of the tensioner on mine but I feel like it’s missing something as I don’t see how it would work as is. I cannot find a parts diagram online for this unit. If anyone has a manual or can point me to a parts diagram I would appreciate it.
/ JD 345 Snowblower
/ JD 345 Snowblower #10
Search the Deere parts website for 42 Inch Snow Thrower. It's there. There are two serial number breaks for the 42 Thrower.
/ JD 345 Snowblower #11
Did you look at the links ?? Apparently not. There are two different snowblowers for different s/n 345's. Suspect you have the later model 345.
/ JD 345 Snowblower
Sorry, I I thought the links were for the mower. That is the correct diagram. Thank you for the help. Not sure why I couldn’t find that as I use the JD parts site frequently. Looks like I’m missing a spring. Thanks again!
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
Gravely Zero Turn Mower (A64194)
Gravely Zero Turn...
2022 EZ-GO ELITE...
