Mowing Fence Mow
/ Mowing Fence Mow #1
walker450
OK
M5040, BX25D, F2880, ZD1211, GR2120, KX-040-4
Not sure how to describe this, but my goal is to cut some of the very tall grass growing under a barb wire fence that I will be taking out. I like the idea of a bar that would stick out approximately 6 inches past the brush hog at an angle to grab grass under the fence and draw it into the brush hog cutting area.... if it was spring loaded it would hit the t-post and go right back each time. I am about to test a stationary version and will post results.
I don't have to cut every blade to the ground, if I can cut most of the grass it will help tremendously.
/ Mowing Fence Mow #2
I've found at best such an idea will clip the tops of that grass off and not cut much of it at all. I've never tried your idea I'm just going off of grass that is laid over and I've mowed it and that is the result. Interested in seeing how it works though as if it works well I will sing your praises and copy it.
/ Mowing Fence Mow
If I could cut even half the grass it would help a lot for what I am doing, once the fence is removed I will brush hog it down nice and low at that time.
I tried the bar and it did not work the way I had it. I think if the bar came from under the actual deck and stuck out it would help.
I don't know how I could do this and it be spring loaded without extensive fabricating, so I will no longer pursue this as an option.
Also, the height of the barb wire is a huge factor as well and slight variations made it impractical.
/ Mowing Fence Mow #4
There is a risk that the bar could get knocked back into the PTO shaft. You do not want the bar to start flaying around the PTO. Could be extremely dangerous, particularly if the PTO shaft launches the bar into your body.
/ Mowing Fence Mow #5
If your fence posts are far enough apart, try backing the end of the mower under it. Pain to keep repositioning, of course.
/ Mowing Fence Mow #6
Dr makes one also
/ Mowing Fence Mow #7
Have you thought of using a spring type arm that's used on a old New Holland hay rack. Would be safer than a bar and it's spring loaded where it mounts.
/ Mowing Fence Mow #9
a sickle bar mowing machine is what you need. slip right under the fence and mow all the way up to the post.
How do you get the bar under the fence wire, on the ground, go 10-16 feet and get it back up and around the next post, and start over?
I think the answer is why all these other ideas have been considered.
  • Good Post
Reactions: JWR
/ Mowing Fence Mow #10
How much fence? Dozens of feet? Hundreds of feet? Miles? That will help decide whether or not it's worth buying something special. There are walk behind string trimmers that might be one possibility.
Is there a reason you can't take the fence out before mowing? Is it something you can spray first?
/ Mowing Fence Mow #12
Just drive making a left turn. It'll swing under and then out. But me, I'd just get the weed eater.
/ Mowing Fence Mow #13
the barb wire fence should be up off the ground. a tractor with a live pto and you with patience... put the tractor in a very low gear and pull up to the post with the bar on the ground and turn the tractor toward the fence and mow under the wire right up to the next post. raise the mower up enough to get the bar off the ground. put in reverse back up carefully untill you can pull out and go to the next post and repeat. after a while you learn how to pull in leaving the bar on the ground and weave in and out under the fence with out backing up every time. with the live pto you can ease up and it will be cutting all the time. if you like keeping your farm trimmed up this is the best machine for the job. with the disc mower and disc bine you just cant get up close to things. i have done this a lot over the years. leaves everything green. anymore i just spray and let it turn brown.
/ Mowing Fence Mow #17
/ Mowing Fence Mow #18
Well, the OP did give me a potential solution to one of the problems I have with the piece-a-junk Bush Hog brand 7' finish mower I bought. The front of the mower is rounded at the corners, following the blade arcs, and it fairly effectively pushes any taller grass to the side, limiting max cutting width. I need to write up a review of my 'experiences' with the Bush Hog factory.
/ Mowing Fence Mow #19
My personal choice for this application is a hedge trimmer attachment for a straight shaft trimmer. Mine is a Troy Bilt attachment purchased at Lowes years ago and used a lot with no issues. I like it for timing under fences, along the sides of a fence for brush, etc that grows through the fence, (on both the customers' side or the neighbors' side of the fence,) for actual hedge trimming, and also ditch trimming. One of the nice features is the adjustable head angle that allows anywhere from the straight shaft position to 90* angles. It has a 16" cutting area and in your situation, you could reach that far under the fence to the other side. This would let you cut that far out on both sides, making it easy to mow up to the fence with the bush hog otherwise. The only downside that I see is if you have a lot of fence to cut along, it makes for a lot of walking. One upside is if you already have a trimer that accepts attachments, you would only need to add this attachment to your list of equipment.
/ Mowing Fence Mow #20
agree, for me a heavy duty bicycle handle/harness weed eater works wonders around my endless pond dams & areas like yours.
i am by no means a fan of glyphosate and feel it's the lazy man's way out. plus hate the look of a sprayed fence line...then again, i don't make my living that way. regards,
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2007 JLG 450AJ SERIES II SKYPOWER TELESCOPIC BOOM (A65056)
2007 JLG 450AJ...
2016 Jeep Compass SUV (A66738)
2016 Jeep Compass...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
2016 John Deere 6155R (A64119)
2016 John Deere...
