What is this lifting ?? tongs for ??
/ What is this lifting ?? tongs for ?? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
Found this in the woods. I can see that it is for lifting something like an I-Beam maybe. It looks like it has a specific purpose. It was near a high tension power line ???? Someone knows what it is, Thanks
gg
/ What is this lifting ?? tongs for ?? #2
Would work for logs, work for ties, work for rails, work for barrels and kegs,
Heck, you could hang a cow from it's hocks with those.
I've got something similar, made of flat iron, sized for 55 gal, drums.
/ What is this lifting ?? tongs for ?? #3
Most likely use was logging. Looks like homemade forging/ welding on ring so probably homebrew tool. Most log hauling tools have slight belly ( bowed legged ) so the points dig into lifted pulled log below the centerline of the log.
That's the thing. If you spread it wide enough for a log, never mind a barrel, the hook angle seems/is all wrong for it to bite in. And to hang a critter, like Cal suggested, I'd want the hooks going the other way and add a spreader. Most of those guys that could make tools back in the day were no dummies. They knew how to make things that worked to do job at hand. I was just wondering what that job might be.
gg
/ What is this lifting ?? tongs for ?? #5
I would lift beams with that all day long. You said that it was near a power lines Perhaps it was used for moving the cross arms around, or for dragging the poles.
/ What is this lifting ?? tongs for ?? #8
Here is link to Natural Museum of American History and ice tongs.
How was the single ring, on Gordon Gould's find, lifted unless there was chain and equipment ( not humans) involved?
All credit for pic goes to National Archives
/ What is this lifting ?? tongs for ?? #9
Granted there are different styles yet here is my bigger pair of ice tongs… shown holding a bucket for demonstration purposes… the same as in the picture above mine.
Someplace I also have a pair of log tongs, which are shaped similar to the above except instead of handles they simply have a ring to hook a chain into… similar to the picture which the OP posted.
/ What is this lifting ?? tongs for ?? #10
Those might be homemade tongs but not good for logging. Most log tongs cross so the harder you pull the harder it bites.
You would have to pound the hooked ends into the log but I'm thinking they would still come loose .
/ What is this lifting ?? tongs for ?? #11
I was thinking ice tongs that maybe could also have been used for lifting and moving hewn logs. As someone else mentioned, they would have been great to hang a hog or steer for butchering as well.
/ What is this lifting ?? tongs for ?? #12
This is what I bought a while back. I use it with a loggers chain to hook onto and pull out sections of trees that I have cut down and need to move out of the way. It has been very useful in those situations - and especially when you cannot get in close with the tractor.
/ What is this lifting ?? tongs for ?? #14
Here’s a pic of the ice tongs I got from my dad. He was born in 1900, so I’m guessing he actually used them in his ice box.
/ What is this lifting ?? tongs for ?? #15
They were also used for harvesting the ice. That was quite an industry, back before refrigeration made it into people’s homes.
/ What is this lifting ?? tongs for ?? #17
It was probably discarded when it did not work for anything useful...:D
And you found it a few decades later...BUT holding a pot over a fire might be a possibility...LOL
/ What is this lifting ?? tongs for ?? #19
Could it be used for a pot over a fire.
VroomVroom,
Of all the comments, I believe yours is closest to the actual use based upon its simple design (not bow legged for points to reach around an object), lack of leverage for driving the points into something ( no pivot point ), and no hand holds.
You are the winner of the mystery prize
Miscellaneous Mini Excavator Attachments (A59228)
Miscellaneous Mini...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
USC Series 2000 Conveyor (A61306)
USC Series 2000...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
