What is this lifting ?? tongs for ??
   / What is this lifting ?? tongs for ?? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
Found this in the woods. I can see that it is for lifting something like an I-Beam maybe. It looks like it has a specific purpose. It was near a high tension power line ???? Someone knows what it is, Thanks
gg
   / What is this lifting ?? tongs for ?? #2
Would work for logs, work for ties, work for rails, work for barrels and kegs,
Heck, you could hang a cow from it's hocks with those.
I've got something similar, made of flat iron, sized for 55 gal, drums.
   / What is this lifting ?? tongs for ?? #3
Most likely use was logging. Looks like homemade forging/ welding on ring so probably homebrew tool. Most log hauling tools have slight belly ( bowed legged ) so the points dig into lifted pulled log below the centerline of the log.
That's the thing. If you spread it wide enough for a log, never mind a barrel, the hook angle seems/is all wrong for it to bite in. And to hang a critter, like Cal suggested, I'd want the hooks going the other way and add a spreader. Most of those guys that could make tools back in the day were no dummies. They knew how to make things that worked to do job at hand. I was just wondering what that job might be.
gg
   / What is this lifting ?? tongs for ?? #5
I would lift beams with that all day long. You said that it was near a power lines Perhaps it was used for moving the cross arms around, or for dragging the poles.
   / What is this lifting ?? tongs for ?? #8
Here is link to Natural Museum of American History and ice tongs.
How was the single ring, on Gordon Gould's find, lifted unless there was chain and equipment ( not humans) involved?
All credit for pic goes to National Archives
   / What is this lifting ?? tongs for ?? #9
Granted there are different styles yet here is my bigger pair of ice tongs… shown holding a bucket for demonstration purposes… the same as in the picture above mine.
Someplace I also have a pair of log tongs, which are shaped similar to the above except instead of handles they simply have a ring to hook a chain into… similar to the picture which the OP posted.
   / What is this lifting ?? tongs for ?? #10
Those might be homemade tongs but not good for logging. Most log tongs cross so the harder you pull the harder it bites.
You would have to pound the hooked ends into the log but I'm thinking they would still come loose .
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52707)
2018 CATERPILLAR...
2019 Bobcat T870 (A53317)
2019 Bobcat T870...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
2022 JOHN DEERE 330G SKID STEER (A52707)
2022 JOHN DEERE...
