Ideas for cannon ball extraction?
   / Ideas for cannon ball extraction?
Short update: Got right/angle drill chuck screwed back on. Attached to extension which was holding the buried bit... pulled trigger and viola, ball came right out.
Now I see the bit is buried in the ball and of course, won't back out. So got my Sawzall out and realized not the right tool. Put it back, got my air chisel out and 3-5 minutes later, buried bit is free. I'll have some pictures, wife & I are preparing to go to town to review/buy some floor tile.
Anyway, so in my excitement, I put flashlight down barrel.... I see something odd.
Put flashlight on spotlight instead of flood. WTH????
Babies?
Thank you to MossyToad for giving someone the idea.... there is a SECOND ball, behind the first....Thank God they didn't put what now appears to be ELEVEN. I thought I only had ten balls (now nine balls and a pile of diced up lead)
The saga continues, more later when I can.
Oh, part II: Yesterday, spoke to the City Cop who's "into this stuff". He's got five cannons. Some of them are what I'd call Civil war type where the wheels are maybe four feet diameter, possibly 5. Pulled behind a horse in those old days.
He's a cop, machinest, some form of engineering degree and is the 'Armorer' (sp?) for the City. He's the one that does all their gun maintainance and fix it up stuff. From what he told me he owns dozens and dozens and dozens of guns, rifles, has built a bunker on his (200 acre) property so he can shoot, store blah blah blah.... He's not into this stuff, he's seriously, into this stuff. Said he'd be happy to come out and look things over before I kill myself! Oh, said he woke up one day, said "I'd like to build myself a cannon" and did so.
Was an interesting conversation.
   / Ideas for cannon ball extraction? #172
Good guy to know.
   / Ideas for cannon ball extraction? #174
Going to try the same process to getthe second one out?
   / Ideas for cannon ball extraction? #175
Ah, that's too bad about the second projectile Richard. Back when those were actually used in warfare, it was not unheard of for crews to do exactly that, under stress of combat, load a second ball by accident. Same also for muskets. Many were found on battlefields after a major skirmish with multiple musket balls loaded in the guns.
It's a good thing you never tried to fire that. With a second ball loaded in the barrel, it would have effectively doubled the amount of chamber pressure when fired. Due to the doubling of the mass and resistance to movement when fired.
When Thompson Center Arms made muzzle loading guns, they would "proof test" their new, modern barrels by placing a double charge of powder underneath 3 patched round balls. This was their "proof charge" and if the barrel would withstand that severe of an overloaded barrel, it was safe to produce and ship to buyers. These were all newly manufactured gun barrels, made like a modern fire arm barrel though. An original black powder gun would have burst from the overpressure.
Here's the ball that came out. The flat side that's on the right side is what I referred to earlier. No idea how/why it's there. No idea if that was part of a deformation issue.
When the drill bit "bit", it ended up spinning the ball. You can see the smooth sides on the ball where it spun in the bore.
Bit was buried SOLID. Rather than try to saw it out, I just got my air chisel and it made short work of it. I didn't want to destroy the ball but I would have been fighting this for a much longer time had I not. Besides, I don't intend to actually fire a cannon ball, just to be cautious AND, since I still have the mass of led, I'm willing to bet I could take it to my newest best cannon friend and he could melt it back into a ball (he sent me some pictures of his ball making tools)
One of my issues on honing the bore is/was the hone is too short. I saw what should work but passed while I thought about it. This morning, I went back to get it thinking I could probably buy a drill extension at Home Depot and extend it. (I was wrong)
Just no way the above is long enough... I meandered through the store...debated on just taking the hone back... then it hit me. The right half screws in....so it will unscrew.
I can go measure it and find out it's a (I forget) 3/16th's 16 thread....and move everything over to a threaded rod...
and viola, I have my extension for the full bore.
Now it's time to take my borescope back down.... this was AFTER a brief running of the hone. To be honest, I don't think I had the hone firm enough but prefer to go slow so I'm ok with that.
Deeper and deeper...I see a shadow....
This is where I started thinking in the back of my head... WHAT the heck is that? Is the back of the bore nice & shiny? Is it a semi circle to help propel the charge forward? I don't know...
and there is the other ball.
I've since cleaned it out some making it easier to see but that was after i took the picture.
Off the cuff, the ball is NOT moving at all. I'm currently letting it soak overnight. I might just drill it out tomorrow if I get fed up with it.
So that's where I currently am. Oh, and I noticed the ball in part because before I put scope down, I put flashlight on flash-hole and did NOT see any light in the cylinder. That perplexed me causing me to go down via scope.
   / Ideas for cannon ball extraction? #179
Hopefully there's only one ball left in the cannon....
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
Warehouse A/C Unit (A47477)
Warehouse A/C Unit...
EZ GO Electric Golf Cart (A53314)
EZ GO Electric...
