How big of a rock/boulder can a 60 HP tractor push on relatively flat dirt?
   / How big of a rock/boulder can a 60 HP tractor push on relatively flat dirt?
Here is an interesting product but can only lift 1500 lbs https://www.paladinattachments.com/sites/default/files/prod_lit/Bradco_Hardscape_Grapple.pdf
Probably makes building rock walls pretty easy
   / How big of a rock/boulder can a 60 HP tractor push on relatively flat dirt? #52
Gotta be honest here. Post #24 - I show a large rock I moved about a half mile to my driveway. This entire move was a REAL PITA. I was so very concerned about potential damage to the tractor FEL. It took the better part of an hour to make the move. Dead slow - grapple leaving drag marks on the ground. I finally made it and I will never go that far afield again for a rock that size. I looked HARDER and found plenty within 100 feet of my driveway. This move didn't cause any damage - it was the bouncing, along the way, that was my concern.
Thanks for the honesty. The more I read the more I think pulling the larger rocks on a stone boat make more sense.
   / How big of a rock/boulder can a 60 HP tractor push on relatively flat dirt? #54
For sure regarding the stone boat. If your eyes get too big and you load up the stone boat too heavy - the worst that can happen - all four tires will start digging their own little hole.
   / How big of a rock/boulder can a 60 HP tractor push on relatively flat dirt? #55
Decide where you want the boulders to go and call a landscape Co. with a small crawler/skid Steer.
Better than breaking your own equipment.
   / How big of a rock/boulder can a 60 HP tractor push on relatively flat dirt? #56
I need to push some fairly large rocks around. I've was able to push many of them with a 70 hp mini excavator with a blade but I am wondering what I can do with a 60 hp tractor. I'm guessing the weight of the equipment and it being able to maintain traction is probably part of the equation.
Throwing this in as a reference
If you think they are too heavy for your bucket (or grapple) I think it's easier to pull them.
   / How big of a rock/boulder can a 60 HP tractor push on relatively flat dirt? #57
For what it's worth........
I have a 2007 Kubota M7040 (68 hp) with 4WD. I tried to move a large rock (3 ft X 4.5 ft X 1.5 ft). Tractor wouldn't pick it up off the ground, but I got my forks under it and was able to push it where I wanted (about 80 yards).
Do I call them for every rock I need to move? That adds up fast if I don't have all of them to move at the same time. Also, around here, charges to just bring the equipment to the land can be $200-$500
   / How big of a rock/boulder can a 60 HP tractor push on relatively flat dirt? #59
with mine I was able to lift a set of concrete stairs on one end and drag them up the road and into the woods. your 3 point can lift more than your FEL and draging 1/2 the weight makes it easier. My tractor is 41hp and I would say I could drag a 3000lb rock.
Also, if you're not moving them far, use a set of long forks and pry them where you want them. I did that with a big granite rock and my tractor did it without breaking a sweat.
Thanks for the feedback. That's what I am thinking. It might not be easy but I should be able to manipulate decent size rocks with a 60HP tractor even if I can't fully lift them off the ground.
UNUSED JCT 72" HYD BRUSH CUTTER (A54757)
UNUSED JCT 72" HYD...
2008 Dodge Ram 1500 (A55788)
2008 Dodge Ram...
2020 CATERPILLAR 305E2 CR EXCAVATOR (A52705)
2020 CATERPILLAR...
UNUSED FUTURE MCLG60-43" MINI CURVED WOOD GRAPPLE (A54757)
UNUSED FUTURE...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
2015 Ford Transit 250 Passenger Van (A55788)
2015 Ford Transit...
