Starlink
   / Starlink #2,561
What happens if you are using the "plain vanilla" Starlink router, but have a mix of network devices-- some with an assigned IP, and some using DHCP?
On bootup, everything works fine on my system. Locally plus also remote access from an off-site location. But after a while, remote access stops working. When that stops working, my wired LAN seems fouled up as well. I'm using the Starlink router, ethernet adapter, then into a network switch that connects to various things. No 3rd party router.
Some of my cameras/camera devices want a fixed IP. But if that is buggering the Starlink lan I will have to figure out a workaround. ???
What were you using before starlink to setup static IP's with. Is it possible that any of your static IP's are conflicting with the SL router IP. One of my disappointments with the SL router was you can't manage or even really see the network. I have a mix of static and DHCP on my network as well. It was much easier to just let SL be my internet connection(WAN) and keep my existing mesh network exactly like it has been, no re-configuring or anything. It's been working great. I bypassed my SL, but could run it's wifi also, but I had no need to, and prefer not having competing wifi's.
   / Starlink #2,562
I used HughesNet prior to Starlink. That worked OK but was very slow.
I found numerous reports (Reddit) about Starlink DHCP sometimes doing inexplicable things-- leading to network lockup. I'm guessing that is happening to me. But I don't know why my wired network works perfectly after a fresh boot, stays perfect for a day or so, but then the wired network crashes.
Seems I am at a fork in the road- a) change my network devices using fixed IP's to dynamic IP, or b) bypass the SL router.
Maybe one other option is to alter my fixed IP's to be outside the range that SL uses for DHCP. Does anyone know what range that is? I've searched but can't find it ...
   / Starlink #2,563
My 3rd gen StarLink router issues IPs in the 192.168.1.xxx range. My wired network uses the 192.168.10.xxx range to avoid conflicts. I haven't disabled anything on the StarLink router, and it seems to be working fine.
   / Starlink #2,564
Do you have any devices with fixed IP's in your network?
I thought just my cameras were fixed IP. Then I remembered I have two nanostation M5's doing wireless transmission to my barn. This are fixed IP also.
   / Starlink #2,565
I would either add a subnet with a second router for your static IP devices, or just go with DHCP and dynamic IP address from Starlink.
The 24 hour time period is strongly suggestive of the issue being an addressing issue, specifically an expired DHCP lease (that typically run for 24 hours).
To the best of my knowledge, there is no data on what range the Starlink router uses, just that it has only has a 127 address table of addresses that it does hand out. I looked as well. You might watch the dynamic addresses and see if you see a pattern.
All the best,
Peter
   / Starlink #2,566
At one time I did, but haven't used static IPs for a long time now. IIRC, I was running a web server I wanted to be accessible by the public, and had to use port forwarding to set that up, which involved establishing a static IP for the web server.
   / Starlink #2,567
That is/was one reason for me having devices with static IP's. But since HughesNet and Starlink both use carrier grade NAT, wanting to do port forwarding is no longer an issue as there is no public facing IP.
My other reason is convenience. When I want to make a minor adjustment to a security camera, I know, by IP, how to get to that exact camera to make the adjustment. But if I adopt a naming scheme for the cameras I think that will work just as well.
I'm soon to eliminate all fixed IP's and we will see how that works.
   / Starlink #2,568
Just got my email notification from Starlink after a 1 1/2 year wait.
Cant wait to get it installed and cancel my horrible HughesNet service. Looking forward to uninterrupted video streaming. Will operate in parallel for a bit to make sure it’s reliable enough.
   / Starlink
Patience is a virtue ... congrats (y)
   / Starlink #2,570
Grab a large mug of your favorite beverage before making the call.
I canceled just now. Took 48 minutes on the phone. By the end I had told them I had already moved into a nursing home, would die soon, been blinded by disease, and didn't know what might happen to my property where the dish and equipment is.
Those subterfuges were in response to:
- we really don't want to lose you as a customer
- don't you really want to keep it?
- could you use it as backup internet?
- could the service move with you?
- what kind of service do you have at your new location?
- could your family still use it at the old location?
- wouldn't a new buyer of your property like to already have high speed internet up and running? (high speed, lol)
I kept being put on numerous "two minute" holds. I began to suspect they could listen in during the holds, even though I could not hear them. Finally, at 45 mins, while on hold, I said: "have you been logging everything on this call? because I think we need to report it ...."
Somehow it was all fixed up within 3 minutes of those utterances ....
Fortunately I had unplugged the modem about 10 days ago. So they saw a cessation of usage on their end.
   / Starlink #2,571
RNG
So you have you Dream Machine Pro plugged into SL, no bypass?
   / Starlink #2,572
RNG
That is correct.
I still can't login to the app to access the Settings menu, so I don't have the option to turn off the SL WiFi.
I also don't understand why speed tests using the SL WiFi are almost double what I get on the Unifi network, but in practical use, it hasn't made much of a difference. Might be something to do with double NAT, or SL's special way of doing NAT, but I'm not savvy enough (or have time enough) to figure that one out.
And after all the reports of good SL performance for a few weeks or months, only to be followed by severe degradations and no SL response, I'm keeping the HughesNet link up as a fallback. I did decrease the data cap, though, saving me a few bux every month.
   / Starlink #2,573
@RedNeckGeek My router is plugged into the Starlink router via the Ethernet adapter and the speed tests are within normal variance of each other. I'm seeing full speed to end devices that are capable of the bandwidth. You might want to check your settings, or contact Starlink to see if they see anything from their side. Have you check the debug information pages?
All the best,
Peter
   / Starlink #2,574
All the best,
Peter
Mine’s handing out .25 to my phone, so that says the lower half, if it is 127 for dhcp. Once I get a computer on mine, I’ll check if it can handle the upper half.
   / Starlink #2,575
I have seen addresses much higher than 127, which is what leads me to believe that the router can handle 127 different addresses (+1 for itself) in the 256 address space. But who knows? The 127 address limit may just have been software at one point in time.
All the best,
Peter
   / Starlink #2,576
All the best,
Peter
I'm also using the SL Ethernet Adapter. Unfortunately, I'm not savvy enough on configuring the UDMPro to understand which settings might be slowing down the LAN WiFi when compared to the SL WiFi.
   / Starlink #2,577
All the best,
Peter
Then the whole network is probably set for dhcp.
I got dish up tonight, but cable still goes under garage door. The app said no interference here.
   / Starlink #2,578
My first suggestion would be login to your UDM and check the dashboard for network usage and speed to see if the upstream (WAN) link is running at the speed you expect. If not, there may be a kinked cable, or bad connection. If that checks out, my next suggestion would be to check that the UDM has DNS servers set to something like 4.4.4.4 and 8.8.8.8 as sometimes switching from a different ISP those settings get left behind and if not altered will make everything slow.
In general, check to see that the UDM has a WAN address in the 192.168.1.N range, and that it is doing DHCP for the 192.168.10.N subnet that you are running. I would double check that any devices with static IPs know that they are 192.168.10.N, and that they are showing up on the UDM correctly.
Then I would check to see what the CPU & memory usage on the UDM. If either one is over 75% or so, you either need a UDM-PRO, or you might want to check the DPI (deep packet inspection) settings and your threat settings. BUT reducing either of those categories reduces your network security.
Crosstalk Solutions over on YouTube has some nice configuration videos on the UDM
and the UDM-PRO,
if you are interested.
What access points are you using with your UDM? (Unless they are quite old, I doubt that they are a problem, but one never knows...)
All the best,
Peter
   / Starlink #2,579
Logged in to Unifi Network app, using Speed test on dashboard page.
On UDMPro WiFi:
Up Down
4.44 34.9
7.04 58.7
5.78 54.0
11.2 83.9
12.2 25.2
8.11 51.34
I can't access the UDMPro subnet when using the StarLink Wifi, so to get an apples to apples comparison, I downloaded a copy of the Ookla Speedtest application and ran it on my MacBookPro laptop.
Using Ookla Speedtest desktop for Mac against Zeta Broadband, Rancho Murieta, CA
On UDMPro SSID On WiFiTemp StarLink SSID
Down Up Down Up
39.1 7.14 124 7.46
39.7 7.49 44.1 6.05
17.0 4.06 66.5 3.42
57.7 8.94 56.2 8.36
42.5 9.96 56.5 9.16
_______________ _______________
39.2 7.52 69.46 6.89
All tests were run between 9:30AM - 10:00AM PST today.
The StarLink WiFi is clearly faster, with one download speed reaching 124 Mbps. I've never seen anything close to that on the UDMPro WiFi.
I'm running a dozen Unifi network cams on the UDMPro using Protect, and five of them are WiFi cams. All five are accessing the same Unifi AC-Pro access point. Disabling the WiFi network cams and repeating the tests on the UDMPro WiFi only shows a slight, maybe 5%, speed increase.
I made an Ethernet cable using Ubiquiti Networks UISP Cable Carrier Cat 5e Shielded Outdoor Ethernet Cable and their shielded connectors. The Network app report that the WAN port on the UDMPro is operating at 1 Gbps.
The UDMPro WAN is set to use 1.1.1.1 and 1.0.0.1 for DNS.
The UDMPro WAN IP is 192.168.1.50, and the UDMPro DHCP server is manually configured to issue addresses in the 192.168.10.6 - 192.168.10.254 range. That seems to be working, as Network shows all devices on that subnet have IP addresses in that DHCP range.
I don't have any devices using static IPs.
Memory usage on the UDMPro is 90%. Here's a plot that shows CPU and Memory usage:
I have disabled both DPI and threat detection. Enabling them doesn't seem to slow things down much.
Three Unifi AC Pros and one AC-LR. As mentioned, the one AC Pro services the four WiFi network cams. Everything else is wired.
On a hunch, I repeated the speed test after I stopped the Protect application on the UDMPro.
Repeated using Gunsmoke SSID with Protect application stopped
Down Up
36.4 10.9
55.2 7.17
37.9 14.6
33.5 9.31
34.3 5.02
39.46 9.4
Download speed was pretty much identical, while upload speed was slightly better. I don't think Protect and the cameras are the problem.
Just for completeness, I used an iPhone Pro12Max to run the StarLink app speedtest while connected to the StarLink Wifi. One run only produced 38 down and 3 up. When I ran the Advanced test, I got 35 down and 7 up router to internet, and 545 down and 52 up iPhone to the StarLink router. That makes it clear that the bottleneck is somewhere in the UDMPro or its associated subnet, but darned if I know where to look for it.
I appreciate the help, ponytug. (y)
   / Starlink #2,580
@RedNeckGeek Wow! Thanks for the detailed information. Very helpful information, and diligent work on your part! When you wrote that you a UDM, I thought that you meant a base Dream Machine. I think that the UDM-PRO router rocks and shouldn't be limiting you in home usage in my opinion.
A UDM-PRO has tons of compute power, so the CPU being overloaded shouldn't be an issue, (and you showed it wasn't) and I would turn the security settings back on. I'm glad that you tried turning protect off; I wondered about disk throughput possibly being an issue, and it clearly isn't.
I forgot to ask earlier, are there errors being thrown in your error log?
I think that all of your APs are fast enough not to be limiting.
When you say that the UDM-PRO is manually configured to do DHCP for 192.168.10.6-254, do you mean that your base LAN is set up to be 192.168.10.1/32, with DHCP service enabled from 192.168.10.6-254? (The UDM-PRO is at 192.168.10.1, right?) (sorry to ask dumb questions)
Is it possible that your UDM-PRO thinks that the WAN link is bandwidth limited? Does the speed setting have something reasonable in it like 400Mbits/s down/100up? (i.e. A little faster than what Starlink might get to) Is it possible that you have your base LAN network setting configured to limit the per user bandwidth? (Normally enabled for guest networks and IOT networks, but not usually enabled for the base LAN) Grasping at straws here.
Have you tried to ping the Starlink router? ping in flood mode?If so what sort of times did you get?
All the best,
Peter
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2020 FREIGHTLINER...
2023 Deere 325G (A60462)
2023 Deere 325G...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2005 WESTERN STAR DUMP TRUCK (A60430)
2005 WESTERN STAR...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
