Starlink
/ Starlink #2,541
I just signed up for T-Mobile home internet
Speeds are pretty good compared to my DSL connection via Frontier.
T-Mobile - $50 per month - 30-177 Mbps Down / 5-20 up
Frontier - $27.99 per month - 6 Mbps Down / 1 up
Going to use T-Mobile until it proves it's reliable (3 months?) and then cancel the DSL. So far is been pretty good, no real complaints yet.
Keep us updated as they are definitely an alternative. I'm curious if there's a slowdown during peak times and throttling if you stream tv a lot.
/ Starlink #2,542
Will do!
Edit: We stream all our TV so I’ll definitely keep my eye on it. Surprisingly we rarely had problems streaming TV via Frontier DSL, so I would hope there isn’t any issues with the new T-Mobile connection
/ Starlink #2,543
Verizon is now offering $25/mo home internet if you have their cell plan. I checked- not available in my area yet.
/ Starlink #2,544
Verizon is whacked. I had their 4G data plans and routers, I even signed up with an independent. The later to remove the data cap and throttling. But they kept saying their Home internet plan was not available for my area. I even went to a store and tried to explain what was going on. No help.
I am on day two of T-Mobile. So far so good, and speeds are three times as fast as my independent Verizon operator.
Needless to say, I don't think I will be a Verizon customer for long. YMMV.
/ Starlink #2,545
My fastest speeds are early in the morning, slows down during the day. I've seen speeds of 225mbps and so far slowest has been 75mbps. I talked to a T Mobil tech yesterday and he said the tower close to my house is going to be upgraded within a month to the enhanced 5G. Said my speeds will increase quite a bit. They still limit the number of internet subscribers per tower. If TMHI was not available I would still be on the waiting list for Starlink.
/ Starlink #2,546
Where to put it.
/ Starlink #2,547
Fastest Starlink speed I have seen is over 300mbps. That is on my system dedicated to a residential address. Slowest I have seen on the Starlink RV system is 4mbps. To be fair, that was one time only. The RV system usually turns in speeds between 50 and 80mbps.
/ Starlink #2,548
I think I might use a J arm that mounts to soffit rather than penetrate the roof. As to where. That would be a combination of clearest view with ease of running the cable. Might need to order longer cable. While you might be able to narrow choices, likely you will have to get on the roof and evaluate with the obstruction app. Note that you should attempt to use the phone apt as close to actual dish location as possible. Some have stood at a spot to evaluate, then placed dish at ground level only to learn that dishy picked up obstructions not seen 3 feet higher. Lots of installs documented on reddit. Some show temp locations for extended duration. SL offers a number of mount options on their site, but I knew I had an old dish J mount sitting in shed. That worked perfectly. Do be careful up there.
/ Starlink #2,549
I got this wineguard mount. Ordered the pipe bracket, which should clamp on this. Waiting on it.
I already bought the longer cable.
Would like to put it on garage facia just above porch roof, but might have interference there. At very top of roof is best choice.
/ Starlink #2,550
With all those peaks Dennis, you have opportunity for fun. I only had to chose which end of a single peak. I choose the nearer.
/ Starlink #2,551
Remember to mount it where you can get to it relatively easily unless you are absolutely positive it won't ever need servicing.
I still remember the picture of David in a tree retrieving an article of value (a drone IIRC).
/ Starlink #2,552
Hey, I resemble that
/ Starlink #2,553
With such a beautiful house Dennis, I opt for hiding it off the back? So you don't see it when walking up.
/ Starlink #2,554
Just make sure to use the obstruction checker tool in the app before you commit to a mounting location. Run it with your phone in the exact physical position you are thinking of mounting the dish. You don't want to find out after the fact that some tree or other object is a blocker that causes your signal to drop occasionally.
/ Starlink #2,555
And do it when the leaves are on the trees. I went from an outage about every 4-5 minutes with no leaves and to an outage every 40-50 seconds once the leaves were on the trees.
/ Starlink #2,556
Bought the pipe bracket
Little big, but I like that the dish snaps in like it does the ground base.
Bracket didnt come with lag bolts, so gotta pick those up.
/ Starlink #2,557
What happens if you are using the "plain vanilla" Starlink router, but have a mix of network devices-- some with an assigned IP, and some using DHCP?
On bootup, everything works fine on my system. Locally plus also remote access from an off-site location. But after a while, remote access stops working. When that stops working, my wired LAN seems fouled up as well. I'm using the Starlink router, ethernet adapter, then into a network switch that connects to various things. No 3rd party router.
Some of my cameras/camera devices want a fixed IP. But if that is buggering the Starlink lan I will have to figure out a workaround. ???
/ Starlink #2,558
Is it possible you need to bypass SL router?
To be honest, just a guess as my networking skill leaves much to be desired. I know I am not bypassing SL in current setup, but wonder if maybe I should be. My SL feeds into a Ubiquiti switch. If I add my security gateway between SL and switch I don’t get internet.
My non optimized system requiring work
/ Starlink #2,559
bad things happen when dhcp servers don't know about static devices. not all check. static devices should be in a separate range, outside of the dhcp scope.
/ Starlink #2,560
Thank you for the idea. I bypassed the SL router at another installation, and that works great.
But in this case, due to distance issues, I hope to keep the Starlink wifi on. That means no bypass. I'm using the SL 150' cable to a desired wifi location, then going wired, after that, off to my network devices. If I bypass the SL router that wifi signal goes away.
If needed I could pull cable back to that location if I have to lose the Starlink wifi, but I'm hoping to avoid that.
2003 NV FLATBED CURTAIN SIDE (A67714)
2003 NV FLATBED...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
2007 VERMEER T755 COMMANDER III TRENCHER (A67714)
2007 VERMEER T755...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2018 JAYCO JAY FLIGHT CAMPER (A67714)
2018 JAYCO JAY...
