confederatemule
- Joined
- Mar 30, 2009
- Messages
- 187
On a Rhino 172 rotary cutter I am not having any luck at removing the bolt that holds the shaft to the cutter gear box. The nut came off easy. I think the bolt is supposed to be easy to pull out. The bolt will barley turn, and then not very far. Is it so rusty that it will not turn? I see no evidence of rust. Do you suppose it has tried to sheer and therefore is no longer straight? It is the original factory bolt. The shaft has a slip clutch.
Thanks for any help.
