PTO shaft bolt removal
   / PTO shaft bolt removal #1
confederatemule
On a Rhino 172 rotary cutter I am not having any luck at removing the bolt that holds the shaft to the cutter gear box. The nut came off easy. I think the bolt is supposed to be easy to pull out. The bolt will barley turn, and then not very far. Is it so rusty that it will not turn? I see no evidence of rust. Do you suppose it has tried to sheer and therefore is no longer straight? It is the original factory bolt. The shaft has a slip clutch.
Thanks for any help.
   / PTO shaft bolt removal #3
Yes,
A punch and a big hammer should do the trick.
Also twisting the shaft / gear box shaft this bolt connects might help (if there is any free play between them)
   / PTO shaft bolt removal #4
First suspicion is the bolt tried to shear and won't come out easily because of that. Put some penetrating oil on it and let it soak for a bit. Then punch/hammer it out. Just watch your fingers. The gear box shaft may tend to move on you as you work on it.
   / PTO shaft bolt removal #5
I agree with the other posters. The bolt is partly sheared and the clutch is partly frozen/rusted to the gearbox shaft. Spray lube on the connection and keep working at it. (y)
   / PTO shaft bolt removal #6
Why worry about it? Just put a new bolt and two crescent wrenches in the tool box and keep going.
2023 LandHonor RB-14-72W 72in Rock Bucket Skid Steer Attachment (A51691)
2023 LandHonor...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A53472)
2022 Gravely...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51692)
2023 Stryker...
2013 Nissan Rogue SUV (A51694)
2013 Nissan Rogue...
