Looking for a source for Lowes (Task Force) parts
/ Looking for a source for Lowes (Task Force) parts #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
The height adjustment knob on my 10" bench table type saw is about to bite the dust. Does anyone know if there is a parts supplier for Task Force equipment?
/ Looking for a source for Lowes (Task Force) parts #2
Have you tried asking Lowes for a parts source?
/ Looking for a source for Lowes (Task Force) parts #3
I buy a fair amount of knobs to restore old tools. Once you know the size of whatever the knob attaches to and whether or not it has threads, it is pretty straightforward.
McMaster-Carr stocks lots of knobs;
https://McMaster.com
Don't forget E-Bay as well.
All the best,
Peter
Thanks Peter,
I probably should have called it a wheel instead of a knob. It has teeth on the bottom for adjusting tilt and grooves in the top for adjusting height. I'm pretty sure it's specific to this saw and I didn't see if at McMaster Carr or ebay. If it doesn't turn up on ebay and Lowes can't help. I think I can make something like the hand crank on an old AC tractor as a workaround.
/ Looking for a source for Lowes (Task Force) parts #6
Thanks Peter,
Yes, that does sound pretty specific, and critical, to your saw. Model #? Photo? I am having trouble visualizing it.
LG sourcing made them for Lowes, but to be honest I am not seeing machine specific parts, and they seem to have moved on from the brand in power tools.
All the best,
Peter
Peter
The first photo shows the blade height adjustment. To raise the blade a spring pushes the wheeI' back so that the roll pin catches between the little bumps around the shaft and spins a threaded rod that raises the blade. The bumps have worn down or broken off and now I can just pull the wheel back enough to make it work. I might rebuild the bumps with some liquid steel type product but think building a crank to fit over the roll pin would be more of a sure thing.
Peter,.
The additional photos are only because you seemed interested in the mechanism. The model number could be hidden under the homemade legs. The wooden "knob" on the wheel works fine, the center hole is probably too big because I was in a hurry and used whatever bit was handy.
/ Looking for a source for Lowes (Task Force) parts #9
/ Looking for a source for Lowes (Task Force) parts #10
Peter,.
Thanks! That really helped. I was having trouble visualizing the dual functions of your knob, but I understand it now.
I can't find a parts source for it, sorry. Your idea of liquid steel seems like a good interim fix. If you are really attached to that saw, our could consider finding a knob that you can cut a slot in for the pin, and source a gear that you can weld/pin to your knob. Alternatively, you could drill out the existing pin engaging lobes and press in a new steel part with lobes or slots to match the pin. (Like half a Lovejoy coupling)
Good luck!
All the best,
Peter
Good luck!
All the best,
Peter
Two good ideas! I hadn't thought about drilling out a slot. One would probably do the job and could probably be done without removing the wheel. That roll pin looks like some disassembly will be required to punch it out.
Thanks,
Stuck
Stuck
/ Looking for a source for Lowes (Task Force) parts #12
Good idea Moss. I think I'll try that.
Sorry if you already did. ;)
You just never know.
Searching for that saw number about the only thing I can find is people buying that saw used, then asking where to get parts or manuals. No luck for any of them.
/ Looking for a source for Lowes (Task Force) parts #13
Thanks,
Stuck
Stuck
Looking at your photos, I was guessing (hoping?) that the rod comes loose somewhere inside, unless you can press the knob in enough to get the pin to clear the knob, which seems awkward. It is a rare machine that is designed for service and repair in my experience.
All the best,
Peter
When I looked inside for a way to get the rod loose, I thought about a homeowner grade chainsaw.
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
1977 FRUEHAUF  C35D-J2-42-6 LOWBOY EQUIPMENT TRAILER (A67714)
1977 FRUEHAUF...
2005 John Deere 225CLE Hydraulic Excavator (A66734)
2005 John Deere...
10ft S/A Utility Trailer (A66738)
10ft S/A Utility...
