Looking for a source for Lowes (Task Force) parts
   / Looking for a source for Lowes (Task Force) parts
Thanks! That really helped. I was having trouble visualizing the dual functions of your knob, but I understand it now.
I can't find a parts source for it, sorry. Your idea of liquid steel seems like a good interim fix. If you are really attached to that saw, our could consider finding a knob that you can cut a slot in for the pin, and source a gear that you can weld/pin to your knob. Alternatively, you could drill out the existing pin engaging lobes and press in a new steel part with lobes or slots to match the pin. (Like half a Lovejoy coupling)
Good luck!
All the best,
Peter
Two good ideas! I hadn't thought about drilling out a slot. One would probably do the job and could probably be done without removing the wheel. That roll pin looks like some disassembly will be required to punch it out.
Thanks,
Stuck
Stuck
   / Looking for a source for Lowes (Task Force) parts #12
Good idea Moss. I think I'll try that.
Sorry if you already did. ;)
You just never know.
Searching for that saw number about the only thing I can find is people buying that saw used, then asking where to get parts or manuals. No luck for any of them.
   / Looking for a source for Lowes (Task Force) parts #13
Thanks,
Stuck
Stuck
Looking at your photos, I was guessing (hoping?) that the rod comes loose somewhere inside, unless you can press the knob in enough to get the pin to clear the knob, which seems awkward. It is a rare machine that is designed for service and repair in my experience.
All the best,
Peter
When I looked inside for a way to get the rod loose, I thought about a homeowner grade chainsaw.
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Hustler super Z zero turn (A56859)
Hustler super Z...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
