Finally.... LS scan tool!
/ Finally.... LS scan tool! #1
LS Tractor Owner
Super Member
Edgewood, NM
LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500
I am sure many will appreciate a scanner specific to to our tractors! Here is a link:
I haven't looked into what the scanner will do yet. Apparently it comes with the adapter from the 6 pin to the 9 pin.
There is a 'pull down' menu to select models.
/ Finally.... LS scan tool! #2
Has anyone bought one I was under impression this was fake site. Been experiencing fake sites for electronic components overseas. Seek out verification before buying. There is a lot of theft happening across the globe on fake real looking web sites.
I did not really look into it, just saw it on the LS facebook site. Yes, I agree to research the seller / product.
They do list an address and a phone number.....
/ Finally.... LS scan tool! #4
Oh it's quite definitely a scam; a quick search of the contact phone number ties it to a bundle of different businesses that seem quite illegitimate.
Well then, I guess it's good to post that it was a scam.... Thanks for the tip!
/ Finally.... LS scan tool! #7
Fwiw- I bought one of their scanners for my XR4155. I had a very satisfactory interaction with them. The only delay i experienced was when I was asked in a follow up email which diagnostic adapter I needed. Being remote from the tractor, it took about 3 weeks before I could confirm the type. I received the unit and adaptor within a week of confirming the adapter configuration.
As yet, I’ve not confirmed it’s functionality with the LS engine electronics. I plan on hooking it up on one of my weekend trips and verify functionality.
Well, that's that.... a legitimate business.
/ Finally.... LS scan tool! #9
Ok we have someone who has vetted the supplier, thanks. Now we need verification tool works as expected please. If this real working tool I myself would like one. Please share your experience when possible this may open opportunity for many LS tractor owners for self repair.
/ Finally.... LS scan tool! #10
They don't have one for my tractor.
/ Finally.... LS scan tool! #11
Does yours have a standard 16 pin OBD2 connector under the column shrouds? My MT240 does and a cheap code reader for a car works great for reading/clearing codes. Has a lot of pids in the live data menu too.
/ Finally.... LS scan tool! #12
In the "pull down" menu, it list P7010.
P7010 is a mechanical injection, EGR engine. No ECU. No DEF. No Regen. I am aware of no electronic control modules on a P7010. What would this device do for a P7010 owner? Unless I do not know the in's and out's of my tractor and missed something.
CT
Don't know why it's listed..... I don't have any use for it either....
Just found this and posted forward for those needing....
/ Finally.... LS scan tool! #14
I bought one of the scanners for my xr4040. After the salesman helped with the adaptor i needed it worked fine. Told me that the dpf filter was clogged up so tractor was in 30 sec run mode.
New Holland Workmaster 75 Tractor (A61166)
New Holland...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
TAG 18in Digging Tooth Bucket Excavator Attachment (A60352)
TAG 18in Digging...
(2) UNUSED 17.5L-24 TIRES W/6 LUG RIMS (A62130)
(2) UNUSED...
2020 Kubota RTV X1140 (A61166)
2020 Kubota RTV...
