CS2410 Mid PTO power loss
/ CS2410 Mid PTO power loss #1
MaxLee
Saratoga, New York
Kioti CS2410
Hello....
When mowing with my MMM I get into a little thicker/heavier grass the mower bogs down and almost stops , engine drops a little rpms. Mower would probably stop if I let it.
I changed oil and all filters, mower deck blades turn free. The mower would never flinch at mowing taller grass.
Any ideas , or point me in a direction would be appreciated.
Thanks
Yeah that works.... but doesn't really solve the problem
/ CS2410 Mid PTO power loss #4
Is the belt driving the blades slipping?
/ CS2410 Mid PTO power loss #5
Should be a drive shaft--- for main drive. BUT-- the mower blade drive belt could be slipping. Is there a spring tensioner or a bolt / slide type adjust? That's the first place to start.
Hello Guys.... Sorry I abandon this thread. I have a few health issue unfortunately but things getting better.
I solved this issue... the PTO leverage is attached to a linkage that goes into the hydrostat , there is a adjustment on this linkage. I made a slight adjustment on the linkage and this solved the problem.
I not sure why this needed to be done... hoping is not to make up for some internal going on or just wear on the linkage. But it works for now.
Thank you all again
/ CS2410 Mid PTO power loss #7
Max
Thanks for reporting back on what resolved your issue.
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A61568)
2012 Ford F-750...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A61307)
2012 MACK Tender...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
Blast Off Hot Pressure Washer Trailer (A61567)
Blast Off Hot...
Case SV280B (A60462)
