Adding a 2-speed pto
/ Adding a 2-speed pto #61
Remember, using a higher speed pto requires a reduction in shear bolt strength to avoid damaging implements gear box.
Dave
I don't agree that the shear pins are affected by a change in tractor engine speed.
Its an interesting subject. Shear pins are selected for their predictable failure at a certain force. As the weak links in the system, they protect other parts from overload.
Its the amount of force at the pin that shears it, not the abruptness of how its applied. A pto-driven system with correctly sized shear pins will be protected regardless of rotation speed. Take care, Dick B.
/ Adding a 2-speed pto #63
As you read what follows please remember I am not trying to argue but only to explain my logic.
As a check, I have emailed COMER who helped with information in the past and once received, I will post their answer.
While force is a main factor, the location of the shear bolt relative to the axis of rotation makes torque critical
COMER lists their shear bolt by TORQUE values as seen in the catalogue cut.
Assuming an 80 HP tractor, I looked at the torque output at two rpms.
At a speed of 540 rpm the 80 HP tractor transmits 778 lb-ft through the pto shaft
At a speed of 1,000 rpm, the same 80 HP tractor transmits 420 lb-ft through the pto.
I am not suggesting the speed of the shearing action makes a difference.
The same 80 HP tractor is transmitting the same power at two different pto speeds.
The lower value of torque at 1,000 rpm's needs a weaker shear bolt to protect both the tractor and the implement.
Dave M7040
......while force is a main factor, the location of the shear bolt relative to the axis of rotation makes torque critical............. The lower value of torque at 1,000 rpm's needs a weaker shear bolt to protect both the tractor and the implement.........
The real question here is what operating condition we are designing to protect the tractor and implement from?
It really has little to do with the torque supplied by the tractor in normal operation. Instead, we are trying to limit the destructive torque that can occur when rotating implements strike immovable obstacles.
Without a shear pin or a slip clutch in the drive line, both tractor and implement can briefly see extreme torque, maybe several times normal. Tractor power is only part of the load. Often the flywheel effect of all the rotating parts can produce a hammer blow torque spike (like when a rotary cutter hits a rock).
The design objective is to prevent broken gears, shafts, keys, etc. Shear pin strength needs to be based on the how much drive line impact torque the tractor or implement can withstand without damage. PTO rpm itself is only contributes indirectly.
I completely agree the shear force depends on torque, whether the pin is mounted perpendicular or parallel, and that the same power at different speeds means different torque, etc. (I used to teach this stuff to engineering students).
About the speed at which the blow imparted, it doesn't matter unless near the speed of sound (much faster than a pin in a spinning pto shaft is going). Drive line loads can be treated as static for figuring stress, etc. Take care, Dick B.
/ Adding a 2-speed pto #65
Perhaps I was one of the dumb ones :)
Lets see what COMER says. Previously, they supplied the opinion the shear bolt needed to be at the implement end of the pto. Few on the forum seemed to agree.
From memory, I think my opinion was formed from reading documents published by one of the big Canadian snowblower manufactures, Normand or Pronovost. They were talking about driving one of their blowers with 3-400 HP tractors. These tractors were normally using 1,000 rpm pto's.
Their blowers, regardless of size, needed to be turned only at 540 rpm and a gearbox was required at the blower end to reduce the 1,000 to 540. "B" in the photo
The documents included the caution to use a smaller shear bolt but I don't recall the location of the bolt.
My comment on speed was from a misunderstanding of your comment in an earlier post.
Dave M7040
.....Lets see what COMER says. Previously, they supplied the opinion the shear bolt needed to be at the implement end of the pto......
It usually makes sense to put it at the implement end of the pto. But maybe a shaft and gearbox rated for 150 hp behind a 300 hp tractor should have its "fuse" at the tractor end. Dick B.
/ Adding a 2-speed pto #67
As long as the PTO shaft is rated higher than the shear pin, it shouldn't matter which end the shear pin is at.
The whole reason for a 1000RPM PTO was to keep PTO shafts to a size that a "normal" human can handle while increasing the torque and horsepower that can be transmitted through them.
As such, a shear pin on a 1000RPM PTO with 80HP going through it will see less torque (and thus less shearing force) than a shear pin on a 540RPM PTO with the same 80HP going through it.
Aaron Z
/ Adding a 2-speed pto #68
You're right on all points - sounds like you did a nice piece of work on your housing.
I know 750 isn't that much more, but it makes the needed difference. The throw distance of 5-10 ft is for heavy wet slushy stuff. Dry powder goes 20 feet even at 540. I know from experience that the 750 pto speed works like a charm with this blower - and with my other stuff.
Project update - using my lift, raised the back end of the L5450 up so pto is 56" off the floor - this pools the oil forward so the pto gearcase comes off without draining the trans. It sure looks nice in there - no wear marks on anything. Kubota painted the inside of the gear housings - nice quality touch. New gears are due to be delivered tomorrow.
How'd you find the Ausie and NZ parts...from your local dealer's parts book. I'd like to do this on my L3700 SU.
Back when I did this the first time (19 years ago!) the L5450/ L4850/L4350 factory parts book included "where used" columns for other countries. These models were derived from earlier ones with the same chassis. Other later models likely share single/dual speed pto parts across markets, but finding the joy for an L3700 will take some digging.
/ Adding a 2-speed pto #70
I converted my one M9 to a 2 speed (540-1000) pto. Should have ordered it that way, way back when but didn't. I use the 21 spline shaft with a 6 spline adapter to power my low power implements like a grain leg. 1325 rpm gives me 540 with the conversion.
/ Adding a 2-speed pto #71
My L4150 had a 2-speed pto, 540 and 750, which was very handy - often I could save fuel, noise and engine wear by running the higher pto speed but with the engine at around 1800. Also, I could run my snowblower up a little to get better throw distance.
My L5450 only has single-speed 540 pto. So I run the engine at 2300 rpm or even higher, but would like a faster pto gear like I had before.
In going over the 5450 parts list, it shows that the tractors in this series made for Australia and New Zealand have 2-speed pto. I've compared the lists and by replacing 2 parts and adding three new ones, my rig will have both 540 and 900 (approx) pto speeds. The parts show as available so they were ordered today. We'll see if this works out.
Anyone have any experience with this? Kubmech?
1-21-02 update - the NZ gears give 900 rpm, and the Aussie gears give 750 (same as my 4150 had) so I'm going Aussie.
im doing the same thing. i have the gears and shafts from a parts tractor. when you say add 3 new parts i am wondering if i need one more part. can you describe the 3 parts please
im doing the same thing. i have the gears and shafts from a parts tractor. when you say add 3 new parts i am wondering if i need one more part. can you describe the 3 parts please?
Hi Ekster,
Looking at post #19 (page 2) the two being REPLACED are the original upper pinion gear shaft and the dummy spacer on the lower shaft. The 3 ADDED parts in post #18 are the new upper pinion shaft, with its removable second pinion, and its mating large gear.
Post #1 focused on the gearing needed for the conversion and didn't include details like the new inner bearing sleeve 32530-25223, new thrust washer 36280-41150 and the gasket. See AU/NZ parts page below - this is what yours should have in it when converted.
Hope this answers your question - take care, Dick
/ Adding a 2-speed pto #73
Okay, reviving this thread once again!
I'm wondering about doing this mod to my ’97 L4850 EverClutch. The thing I use the most and expect to for the rest of the tractor or my life 😬 is a 62” Ibex flail mower, to shred brush and tree prunings. Its required HP is way lower than my tractor puts out, but I wanted a mower that would stay within the wheelbase so I don't get caught driving between trees etc. Also wanted to be able to potentially use it as a front implement on my bobcat 743, with a 3pt SSQA reciever+hydraulic 540rpm motor.
So my thinking is that with the conversion and running the engine at lower rpms to get the 540 rpm @ implement, my diesel consumption would be much less over time.
The big question is: is this appropriate for tractor and implement? I don't know enough details about engine/pto physics to decipher whether this approach would wear badly on the tractor or implement.
Also, do you think the parts are still readily available for the conversion? I'm not in a rush, so am happy to wait and find used parts for cheap if possible.
TIA
/ Adding a 2-speed pto #74
They must use metric minutes over there.
TIA
New parts may be available - try googling a part number to see.
But used parts will be way cheaper. And as time goes on, more of the older L3 machines with 2-spd pto will appear in salvage yards.
I wanted the higher pto speed for snow blowing and running a generator at lower (quieter) engine speed. Fuel usage is actually not that different because the actual work being done at the implement is the same. Dick B
/ Adding a 2-speed pto #76
That's interesting, I always assumed higher engine rpms meant higher fuel consumption, despite the physical demand from work being done.
So if I were to use, say, a sicklebar mower that takes very little HP to run, on my oversized (for the implement) tractor, it wouldn't use significantly less fuel whether I'm running it at 2300 engine rpms with the current 540 PTO gearing, or at (ballpark guess) 1600 engine rpms on the 720 PTO setting?
My flail mower would definitely pull more power out of the tractor than a sicklebar, but being that it's undersized for my tractor HP, I was thinking that it might be able to handle the flail at lower engine rpms and use less fuel. But if it's not going to use significantly less, then I probably don't want to invest the time and energy into the PTO conversion, unless I get into using a sicklebar mower a lot. ..
Thanks!
Out of curiosity I priced the 5 parts needed - they still show as available but the current total is $1724. The 42T gear alone is over $900. No longer makes sense unless used L3350, L3750 or L4150 pto parts can be found.
/ Adding a 2-speed pto #78
Unless a tractor has a lot more hp than you need on a pto generator to make the power needed, it just doesn't work very well to run one at a lower engine rpm, than would normally be needed to make 540 on the pto.
SR
9/8/22 - just noticed online an available complete pto gearbox from a L3750. Whole box, easy bolt-on 2-speed pto conversion for later-model L4350, L4850 or L5450. (notified Brambleberry by pm)
SCAN TO RECEIVE TEXT UPDATES (A62131)
SCAN TO RECEIVE...
UNUSED JCT 84" HYD DOZER BLADE (A62131)
UNUSED JCT 84" HYD...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
New/Unused Wolverine 45in Bucket Clip on Pallet Forks (A61166)
New/Unused...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59909)
2005 INTERNATIONAL...
2014 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
