Wrong oil! (stupid on me)
/ Wrong oil! (stupid on me) #1
BubbaBillyBob
Rockbridge, MO
Mahindra 5545 4wd
All--
I changed the oil in my Mahindra 5545 (9 quarts) and my Komatsu SK1020-5 Turbo (10 quarts) skid steer today. I decided to use 15W-40 in the tractor and 10W-30 in the skid steer, using the temperature range shown in their respective manuals.
Except, I screwed up. I flipped them: The 10W-30 went into the tractor and the 15W-40 went into the skid steer.
Should I do it all over with new filters and oil?
I only feel stupid when I think about it.
--Bill
/ Wrong oil! (stupid on me) #3
same I would leave it ... if something flush only the skid steer and keep the oil for next oil change for your tractor ... definitely leave your filter in you didn't used it its sill new
/ Wrong oil! (stupid on me) #5
Your still protected.
/ Wrong oil! (stupid on me) #6
Don't think it matters. I'd use 10w30 in both. If they're both cooled by coolant, the oil has to stand up to about 210-230 F from the 195 F thermostat in the coolant. Doesn't matter what the outside temperature is.
Gentlemen!
Thank you for the assurances and advice. I will pick one weight and stick to it next time around. The good news is I never told my wife I tossed $258 down the drain.
--Bill
/ Wrong oil! (stupid on me) #8
What oil did you buy that cost $258 for 19 quarts and 2 filters?
/ Wrong oil! (stupid on me) #10
No coffee and donuts for the next 6 months for that
mix up🤣
willy
4570Man--
I am going to answer your question. I just need some time on the computer to do so. I might learn something if you--or others--see what I bought and how much it cost.
--Bill
/ Wrong oil! (stupid on me) #12
That's awfully harsh don't you think?
Maybe 3 weeks on the donuts & 3 days on the coffee.
/ Wrong oil! (stupid on me) #13
I did the same thing but with my 2500HD truck and my LS4145 tractor. After rechecking the manuals and finding I was still well within specs I let it ride. If it fits the manufacturer specs then don't sweat it.
/ Wrong oil! (stupid on me) #15
I wouldn't worry too much as long as they are both diesel rated oils.
Personally I run 5W-40 Diesel rated in most all my engines.
/ Wrong oil! (stupid on me) #16
I'm curious, what made you think to use different oils in the first place? Both diesel, right? Do either of the machines have a DPF or EGR system? Older engines with EGR systems can use API CE through CI-4 rated oils, while newer engines, including those with a DPF, should use CJ-4. My skid steer, excavator, dozer, and truck all use the same 15w-40 CJ-4 engine oil.
/ Wrong oil! (stupid on me) #17
All--
--Bill
Nope. It'll all work out!
Bob--
The Komatsu skid steer is a 2005 machine. No environmental stuff. The 2016 Mahindra 5545 has none, either.
What made me think to use different oils? I screwed up. I bought what I wanted for each machine and then--like a dummy--proceeded to switch them.
--Bill
4570Man--
I bought more than I wrote: All from O'Reilly Auto Parts . . .
Wix 4671 Air Filter . . . . . . . $61.99
Wix 51334 Oil Filter . . . . . . . 11.99
12qts Motorcraft 15W-40 . . . 98.97
12qts Mobil 10W-30 . . . . . . .65.97
Sales Tax . . . . . . . . . . . . . $19.65
Total . . . . . . . . . . . . . . . $258.57
All the oil is diesel rated. Plus, I had to go back and buy the internal air filter for the Komatsu. I forgot what it cost.
--Bill
/ Wrong oil! (stupid on me) #20
A local parts store charged me that much for an air filter. The Kubota branded air filter from the dealer was 1/2 that price.
2011 INTERNATIONAL WORKSTAR 7300 CHEMICAL BOBTAIL (A65643)
2011 INTERNATIONAL...
3" Steel Posts (A66408)
3" Steel Posts...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
Gravely Zero Turn Mower (A64194)
Gravely Zero Turn...
2021 John Deere Gator TX4x2 Turf Utility Cart (A64194)
2021 John Deere...
